OS Ubuntu 16.04.
I have installed the ncsdk 2 from the following source:
"git clone -b ncsdk2 https://github.com/movidius/ncsdk.git"
Install and make examples: OK
I have tested the NCS installation using the hello apps with success.
I want to use the the application "image-classifier" from ncappzoo, source:
"git clone https://github.com/ashwinvijayakumar/ncappzoo"
When I execute "make run" or #python3 image-classifier.py , I receive the following error:
AttributeError: module 'mvnc.mvncapi' has no attribute 'EnumerateDevices'
When I execute the Hello apps within the ncappzoo I have some errors, the last lines below:
cpp/hello_ncs.cpp:40:43: error: ‘mvncCloseDevice’ was not declared in this scope
retCode = mvncCloseDevice(deviceHandle);
cpp/hello_ncs.cpp:42:20: error: ‘MVNC_OK’ was not declared in this scope
if (retCode != MVNC_OK)
Makefile:10: recipe for target 'hello_ncs_cpp' failed
make: *** [hello_ncs_cpp] Error 1
For your information, the Python3 path output is:
python3 -c "import sys; print('\n'.join(sys.path))"
/opt/workspace/ncappzoo/apps/hello_ncs_cpp
/opt/movidius/caffe/python
/usr/lib/python35.zip
/usr/lib/python3.5
/usr/lib/python3.5/plat-x86_64-linux-gnu
/usr/lib/python3.5/lib-dynload
/usr/local/lib/python3.5/dist-packages
/usr/lib/python3/dist-packages
Why the examples in the NCSDK run and the applications from ncappzoo do NOT work?
Please, do you have some suggestions to solve it?
Thank you
- Tags:
- Python3
Have you switched to the ncsdk2 branch of the ncappzoo repository?
Topic Options
