I bought a Neural Compute Stick 2 and I'm trying to install the NCSDK on my raspberry pi. However, the installations fails while compiling the caffe. I get an error on line 648.
I can install successfully the NCSDK without installing caffe, but when I tried running the mvNCCompile command I got an error that the module "caffe" could not imported. Can you help me?
EDIT: I commented the import lines for Caffe in the parsers of mvNCCompile and now I can get it working without it. However, I'm trying to convert a tensorflow model and what I get when running the mvNCCompile is this:
[Error 5] Toolkit Error: Stage Details Not Supported: Top Not Found conv1d_1/convolutions/ExpandDims
- Tags:
- Caffe
- Raspberry Pi
Hi @Mortis19
The error you are seeing [Error 5] Toolkit Error: Stage Details Not Supported: Top Not Found conv1d_1/convolutions/ExpandDims is related to the layer profile from caffe which is generated when caffe is downloaded and built. Could you copy/paste the error message that was prompted during the make install? Are you trying to install the ncsdk version 1 or 2?
Also, I undersand you are using an Intel Neural Compute Stick 2. NCS 2 is only supported on OpenVINO and will not work with the ncsdk. There was a recent OpenVINO release (R5) that provides preview support for Raspbian* 9, please checkout the release notes for more info. I have not tried to install OpenVINO on the RPi, give it a try and post any issues on the OpenVINO forum.
Please take a look at the getting started page for the NCS 2 to install OpenVINO.
https://software.intel.com/en-us/neural-compute-stick/get-started
I will recommend posting any issues you run into on the OpenVINO forum.
https://software.intel.com/en-us/forums/computer-vision
Jesus
