I am trying to compile a _very_ simple neural network written in TensorFlow and saved as a .meta graph. The network was taken directly from this tutorial:
http://stackabuse.com/tensorflow-save-and-restore-models/
which I followed in order to learn how to save and restore graphs. I have made minor changes to name inputs and outputs (I'm including all my Python notebooks and the saved .meta). When trying to compile using mcNCCompile
I am stuck on the TensorFlow error:
tensorflow.python.framework.errors_impl.InvalidArgumentError: Input 1 (tensor_name) must be a string scalar; got a tensor of 2elements
[[Node: save/RestoreV2 = RestoreV2[dtypes=[DT_FLOAT, DT_FLOAT], _device="/job:localhost/replica:0/task:0/device:CPU:0"](_arg_save/Const_0_0, save/RestoreV2/tensor_names, save/RestoreV2/shape_and_slices)]]
It is not obvious to me where it expects a tensor with a type "string scalar" and so I'm not clear where it is being fed a tensor of "2elements".
This was intended to be a simple test of mvNCCompile
. This command is giving me errors on a larger, more complicated network and I wanted to run a simple experiment with a simple network to help me better understand the process. I am disappointed that I am still running into hiccups here. Any help would be much appreciated.
I am including my code below. I tried uploading the files but they aren't allowed (!?). I cannot upload the .meta file either (why can't I attach any files???). The .meta can easily be produced by running SaveTest.py as long as there is a folder named "saved" in the same directory.
After producing the .meta graph I can produce the error by running:
mvNCCompile model_final.meta -in=X -on=y
or even just
SaveTest.py
This file builds, trains and saves the network.
import tensorflow as tf
import numpy as np
import matplotlib.pyplot as plt
tf.reset_default_graph()
X = tf.placeholder(tf.float32, name="X")
Y = tf.placeholder(tf.float32, name="y")
h_est = tf.Variable(0.0, name='h_estimate')
v_est = tf.Variable(0.0, name='v_estimate')
y_est = tf.square(X - h_est) + v_est
cost = (tf.pow(Y - y_est, 2))
trainop = tf.train.GradientDescentOptimizer(0.001).minimize(cost)
h = 1
v = -2
x_train = np.linspace(-2, 4, 201)
noise = np.random.randn(*x_train.shape) * 0.4
y_train = (x_train - h) ** 2 + v + noise
plt.rcParams['figure.figsize'] = (10, 6)
plt.scatter(x_train, y_train)
plt.xlabel('x_train')
plt.ylabel('y_train')
saver = tf.train.Saver()
init = tf.global_variables_initializer()
def train_graph():
with tf.Session() as sess:
sess.run(init)
for i in range(100):
for (x, y) in zip(x_train, y_train):
sess.run(trainop, feed_dict={X: x, Y: y})
saver.save(sess, 'saved/model_iter', global_step=i)
saver.save(sess, 'saved/model_final')
print("Training complete!")
h_ = sess.run(h_est)
v_ = sess.run(v_est)
return h_, v_
result = train_graph()
print("h_est = %.2f, v_est = %.2f" % result)
RestoreTest.py
This file reloads the network via the saved .meta and prints
the learned parameters
import numpy as np
imported_meta = tf.train.import_meta_graph("saved/model_final.meta")
imported_meta.restore(sess, tf.train.latest_checkpoint('saved'))
h_est2 = sess.run('h_estimate:0')
v_est2 = sess.run('v_estimate:0')
print("h_est: %.2f, v_est: %.2f" % (h_est2, v_est2))
- Tags:
- Tensorflow
