Trying to run cmake on ./opt/intel/computer_vision_sdk_2018.5.445/deployment_tools/inference_engine/src/extension/CMakeLists.txt. Initially, it fails to find ext_message. Editing the file to
include(InferenceEngineConfig-version)
include(InferenceEngineConfig)
seems to remediate that particular problem, however, then we're seeing
CMake Error at CMakeLists.txt:30 (add_library):
add_library cannot create target "ie_cpu_extension" because another target
with the same name already exists. The existing target is a shared library
created in source directory
"/opt/intel/computer_vision_sdk_2018.5.445/deployment_tools/inference_engine/src/extension".
See documentation for policy CMP0002 for more details.
CMake Error at /opt/intel/computer_vision_sdk_2018.5.445/deployment_tools/inference_engine/share/ie_parallel.cmake:93 (target_link_libraries):
Attempt to add link library
"/opt/intel/computer_vision_sdk_2018.5.445/deployment_tools/inference_engine/external/omp/lib/libiomp5.so"
to target "ie_cpu_extension" which is not built in this directory.
Call Stack (most recent call first):
CMakeLists.txt:31 (set_ie_threading_interface_for)
CMake Error at CMakeLists.txt:35 (target_link_libraries):
Attempt to add link library "IE::inference_engine" to target
Any advice on that?
Seems like Windows fails to build in a similar manner in R5. Is there any documentation on how to build the extensions anywhere?
Weird - both Linux and Windows version build fine here with R5
What is your cmake, OS/kernel, tools/compiler version?
Also maybe uninstall R4 or previous versions of the SDK just in case.
cheers,
nikos
What happens if you build extensions as a sub-project of the samples solution ?
i.e. on Windows cmake under C:\Intel\computer_vision_sdk_2018.5.445\inference_engine\samples
So, apparently, extensions CMakeLists.txt cannot be as a standalone project. They reference macros from InferenceEngineConfig, which in turn adds extensions subfolder to the build. However, creating a rudimentary top-level CMakeLists.txt
cmake_minimum_required(VERSION 3.9)
works fine.
CMAKE_BUILD_TYPE not defined, 'Release' will be used
CMake Error at /opt/intel/computer_vision_sdk/deployment_tools/inference_engine/samples/extension/CMakeLists.txt:27 (add_library):
"/opt/intel/computer_vision_sdk/deployment_tools/inference_engine/src/extension".
Trying to use facenet with openVINo but when i run cmake .. then getting above error .
Any advice on that?
What is /opt/intel/openvino/deployment_tools/inference_engine/src/extension about?
And, this extension is NOT able to be built independently?
CMake Error at CMakeLists.txt:46 (set_ie_threading_interface_for): Unknown CMake command "set_ie_threading_interface_for".
How can I have it built then?
Cheers
Pei
