python3 ~/intel/computer_vision_sdk_2018.5.445/deployment_tools/model_optimizer/mo_tf.py --input_model /media/carson/New\ Volume/vision/keras/saved_models/NasMobi.pb --input_checkpoint /media/carson/New\ Volume/vision/keras/saved_models/NasMobi.ckpt --scale_values [255,255,255] --input_shape [1,3,224,224] --output_dir /media/carson/New\ Volume/vision/NCS/bin_xml/FP16 --data_type FP16 --model_name NasMobi
Model Optimizer arguments:
Common parameters:
- Path to the Input Model: /media/carson/New Volume/vision/keras/saved_models/NasMobi.pb
- Path for generated IR: /media/carson/New Volume/vision/NCS/bin_xml/FP16
- IR output name: NasMobi
- Log level: ERROR
- Batch: Not specified, inherited from the model
- Input layers: Not specified, inherited from the model
- Output layers: Not specified, inherited from the model
- Input shapes: [1,3,224,224]
- Mean values: Not specified
- Scale values: [255,255,255]
- Scale factor: Not specified
- Precision of IR: FP16
- Enable fusing: True
- Enable grouped convolutions fusing: True
- Move mean values to preprocess section: False
- Reverse input channels: False
TensorFlow specific parameters:
- Input model in text protobuf format: False
- Offload unsupported operations: False
- Path to model dump for TensorBoard: None
- List of shared libraries with TensorFlow custom layers implementation: None
- Update the configuration file with input/output node names: None
- Use configuration file used to generate the model with Object Detection API: None
- Operations to offload: None
- Patterns to offload: None
- Use the config file: None
Model Optimizer version: 1.5.12.49d067a0
[ FRAMEWORK ERROR ] Cannot load input model: Input 0 of node replica_0/model/stem_bn1/cond/ReadVariableOp/Switch was passed float from stem_bn1/gamma:0 incompatible with expected resource.
python3 ~/intel/computer_vision_sdk_2018.5.445/deployment_tools/model_optimizer/mo_tf.py --input_model /media/carson/New\ Volume/vision/keras/saved_models/test.pb --input_checkpoint /media/carson/New\ Volume/vision/keras/saved_models/test.ckpt --scale_values [255,255,255] --input_shape [1,3,256,256] --output_dir /media/carson/New\ Volume/vision/NCS/bin_xml/FP16 --data_type FP16 --model_name test
Common parameters:
- Path to the Input Model: /media/carson/New Volume/vision/keras/saved_models/test.pb
- IR output name: test
- Log level: ERROR
- Input shapes: [1,3,256,256]
[ FRAMEWORK ERROR ] Cannot load input model: Input 0 of node batch_normalization_188/cond/ReadVariableOp/Switch was passed float from batch_normalization_188/beta:0 incompatible with expected resource.
