6605 Discussions
Cannot load library 'CPU': CPU: cannot open shared object file: No such file or directory
王__伟
 /** 载入默认扩展库 **/
    if (DEVICE.find("CPU") != std::string::npos) {
        InferenceEngine::IExtensionPtr extension_ptr=InferenceEngine::make_so_pointer<InferenceEngine::IExtension>(“CPU”);
        ie.AddExtension(extension_ptr);
出错
echo $LD_LIBRARY_PATH
/home/feiyu/openvino_2021/data_processing/dl_streamer/lib:/home/feiyu/openvino_2021/data_processing/gstreamer/lib:/home/feiyu/openvino_2021/opencv/lib:/home/feiyu/openvino_2021/deployment_tools/ngraph/lib:/home/feiyu/openvino_2021/deployment_tools/inference_engine/external/tbb/lib::/home/feiyu/openvino_2021/deployment_tools/inference_engine/external/hddl/lib:/home/feiyu/openvino_2021/deployment_tools/inference_engine/external/omp/lib:/home/feiyu/openvino_2021/deployment_tools/inference_engine/external/gna/lib:/home/feiyu/openvino_2021/deployment_tools/inference_engine/external/mkltiny_lnx/lib:/home/feiyu/openvino_2021/deployment_tools/inference_engine/lib/intel64
Zulkifli_Intel
Hello 伟 王,
Greetings to you.
Please help us to provide more information such as commad or custom code you are using. Share with us more details that can help us to reproduce the issue.
Zulkifli
Zulkifli_Intel
Hello, thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Zulkifli
