/usr/local/bin/ncsdk/Controllers/Parsers/TensorFlowParser/Convolution.py:44: SyntaxWarning: assertion is always true, perhaps remove parentheses?
assert(False, "Layer type not supported by Convolution: " + obj.type)
mvNCCompile v02.00, Copyright @ Intel Corporation 2017
shape: (1,)
Traceback (most recent call last):
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/client/session.py", line 1278, in _do_call
return fn(*args)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/client/session.py", line 1263, in _run_fn
options, feed_dict, fetch_list, target_list, run_metadata)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/client/session.py", line 1350, in _call_tf_sessionrun
run_metadata)
tensorflow.python.framework.errors_impl.InternalError: Unable to get element as bytes.
During handling of the above exception, another exception occurred:
File "/usr/local/bin/mvNCCompile", line 169, in
create_graph(args.network, args.image, args.inputnode, args.outputnode, args.outfile, args.nshaves, args.inputsize, args.weights, args.explicit_concat, args.ma2480, args.scheduler, args.new_parser, args)
File "/usr/local/bin/mvNCCompile", line 148, in create_graph
load_ret = load_network(args, parser, myriad_config)
File "/usr/local/bin/ncsdk/Controllers/Scheduler.py", line 100, in load_network
parse_ret = parse_tensor(arguments, myriad_conf)
File "/usr/local/bin/ncsdk/Controllers/TensorFlowParser.py", line 294, in parse_tensor
res = outputTensor.eval(feed_dict)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/ops.py", line 680, in eval
return _eval_using_default_session(self, feed_dict, self.graph, session)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/ops.py", line 4951, in _eval_using_default_session
return session.run(tensors, feed_dict)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/client/session.py", line 877, in run
run_metadata_ptr)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/client/session.py", line 1100, in _run
feed_dict_tensor, options, run_metadata)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/client/session.py", line 1272, in _do_run
run_metadata)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/client/session.py", line 1291, in _do_call
raise type(e)(node_def, op, message)
I use the default /tensorflow/inception-v1 , I can compile graph success
but I still use the inception-v1 interface and use the data of myself , then the errors comes
thanks a lot
@GrantTeng It looks like you're having issues compiling the graph file here, but you said you were able to compile the graph file? Can you try running make run
and see if the python script for inception_v1 executes?
Just to be clear, are you using a custom inception _v1 model that is trained with your own data? If so, can you provide the model so that I can reproduce this issue on my machine also? Thanks.
Thanks a lot ,I have found the bugs,the input dimensions is not right.
@GrantTeng I'm glad you were able to figure it out.
