6586 Discussions
Conversion problem for Pytorch MaxPool2d layer to Openvino
Neslihan_K_Intel
I would like to use pytorch MaxPool2d(kernel_size = 3, stride=1, padding=1) layer in OpenVino. I initially convert the layer to onnx format. However while converting to IR representation, I receive the following error:
failed:[ShapeInferenceError] Attribute pads has incorrect size
I tried also without padding and still receive the same error message.
I would like to learn if this Pytorch layer is supported in OpenVino or not. I will be glad if you can help me to solve the problem.
SuryaPSC_Intel
Hi Neslihan,
Can you please share the model architechture.
Also, please note that MaxPool2D operation is applied to the output of the previous layer, and cannot work without an input. So, kindly make sure to provide an input to the MaxPool2D operation.
Surya
