6592 Discussions
Converting a frozen .pb graph file to NCS graph
I'm trying to convert a frozen graph generated using darkflow and YOLO v2 (not tiny) trained on the COCO dataset.
I tried running:
mvNCCompile -in input -on output mygraph.pb -s 12
but I am getting an error as below:
[Error 17] Toolkit Error: Internal Error: Could not build graph. Missing link: concat
Is there a way to convert this custom model to NCS graph?
I've also tried converting the YOLO .cfg and .weights to a caffe model but then, I am thrown with an error saying "Error: size mismatch"
If this is not possible, is there any other model trained on the COCO dataset that I can use? It'll be great if someone can share a prebuilt graph also.
