Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Debug OpenVINO applications using Docker and Intel System Studio
I have installed Intel System Studio with docker to run OpenVINO applications. I have been able to run many OpenVINO applications(in Run configuration), but there seem to be an issue if i do that in Debug configuration(Debug As local C/C++ application) . It keeps giving the error:
Error message from debugger back end:
~/HOME/.gdbinit: No such file or directory. There is an empty .gdbinit file in my home directory. I am trying to run this app locally on an Ubuntu 16.04. It's a VM on my Fedora host, but i am thinking that shouldn't be any issue since i have been able to run the Security_Barrier OpenVINO app in Run configuration.
These are my settings for Debug config:
GDB debugger: /opt/intel/system_studio_2019/debugger_2109/gdb/intel64/bin/gdb-ia
GDB command file: ${system_property:user.home}/.gdbinit
If i run it as Debug As Remote Application, i get the following error:
"Failed to start gdbserver on target using connection local". I have set up connection using Address: "localhost". Also "Gdbserver Settings" has
Gdbserver name: /home/naveenk1/gdbserver
Port number: 2345
Any suggestions here would be helpful.
Naveen
Highlighted
The issue seems to be originating from the usage of gdb component from Intel® System Studio. I request you to contact the Intel® System Studio support team for the same. Intel employees are advised to use Intel internal forums for any technical queries.
Highlighted
Thanks for letting know. I will follow up internally with Intel System Studio team.
