Hi, I try to run my own model with ncsdk, and my system is ubuntu16.04. I run the code in virtual environment, I find solutions online which is downupgrading tensorflow from 1.6 into 1.3, and I tried this, but I still get this error. Any help would be appreciated.
@Tome_at_Intel
https://github.com/Derekabc/Movidius-keras there is my code.
Firstly, I train the model by keras, and then I convert it into tensorflow model.
Secondly. I use the command below to check, compile, profile the model into graph file.
mvNCCheck TF_Model/tf_model.meta -in=conv2d_1_input -on=dense_2/Softmax
mvNCCompile TF_Model/tf_model.meta -in=conv2d_1_input -on=dense_2/Softmax
mvNCProfile TF_Model/tf_model.meta -in=conv2d_1_input -on=dense_2/Softmax
@DongDong It would save me a lot of time if you could provide a link to your meta/index files so that I can test them. Thanks.
Thank you for your reply. I have updated the meta/index files on Github.
And the command for compiling, Checking and profiling as following.
mvNCCheck TF_Model/tf_model.meta -in=input_1 -on=dense_1/Softmax
mvNCCompile TF_Model/tf_model.meta -in=input_1 -on=dense_1/Softmax
mvNCProfile TF_Model/tf_model.meta -in=input_1 -on=dense_1/Softmax
Thank you very much!!
@DongDong Thank you for providing your model files. We were able to reproduce your issue and are looking into the issue.
@Tome_at_Intel Thank you Tome, I am looking forward to your reply! I have struggled against this error for one week!
