I just prototyping a model in tf.keras following the link below:
https://www.dlology.com/blog/how-to-run-keras-model-on-movidius-neural-compute-stick/
I converted my Keras model to tensorflow, but when I tried to compile my tensorflow model to graph, it gives me error below:
[Error 5] Toolkit Error: Stage Details Not Supported: VarHandleOp
my tensorflow version is 1.9.0
my model:
model = models.Sequential()
model.add(layers.Flatten(input_shape=(28,28)))
model.add(layers.Dense(128,activation='relu'))
model.add(layers.Dense(10,activation='softmax'))
model.compile(optimizer='adam',loss = 'sparse_categorical_crossentropy',metrics=['accuracy'])
using this command to compile:
mvNCCompile tf_model.meta -in=flatten_1_input -on=dense_5/Softmax
error:
mvNCCompile v02.00, Copyright @ Intel Corporation 2017
_* Info: No Weights provided. inferred path: tf_model.data-00000-of-00001_*
shape: [1, 28, 28]
I have tried another model structure but I ended up facing the same error
Thank you.
I am facing the same issue. I have taken inception_v3 and did transfer learning on it by adding last layer as dense
. I have used tf.saved_model.simple_save
to export the model.
Following is the error I get:
pi@raspberrypi:~$ mvNCCompile -s 12 _retrain_checkpoint.meta -in=Placeholder -on=final_result -o first_graph.graph
/usr/lib/python3/dist-packages/scipy/_lib/_numpy_compat.py:10: DeprecationWarning: Importing from numpy.testing.nosetester is deprecated since 1.15.0, import
from numpy.testing instead.
from numpy.testing.nosetester import import_nose
/usr/lib/python3/dist-packages/scipy/stats/morestats.py:16: DeprecationWarning: Importing from numpy.testing.decorators is deprecated since numpy 1.15.0, impo
rt from numpy.testing instead.
from numpy.testing.decorators import setastest
/usr/lib/python3.5/importlib/_bootstrap.py:222: RuntimeWarning: compiletime version 3.4 of module 'tensorflow.python.framework.fast_tensor_util' does not matc
h runtime version 3.5
return f(*args, **kwds)
/usr/lib/python3.5/importlib/_bootstrap.py:222: RuntimeWarning: builtins.type size changed, may indicate binary incompatibility. Expected 432, got 412
/usr/local/bin/ncsdk/Controllers/Parsers/TensorFlowParser/Convolution.py:46: SyntaxWarning: assertion is always true, perhaps remove parentheses?
assert(False, "Layer type not supported by Convolution: " + obj.type)
/usr/local/bin/ncsdk/Controllers/Parsers/Phases.py:322: SyntaxWarning: assertion is always true, perhaps remove parentheses?
assert(len(pred) == 1, "Slice not supported to have >1 predecessors")
****** Info: No Weights provided. inferred path: _retrain_checkpoint.data-00000-of-00001******
WARNING:tensorflow:From /usr/local/lib/python3.5/dist-packages/tensorflow/python/training/saver.py:1266: checkpoint_exists (from tensorflow.python.training.ch
eckpoint_management) is deprecated and will be removed in a future version.
Instructions for updating:
Use standard file APIs to check for files with this prefix.
shape: [1, 299, 299, 3]
I have confirmed the name of the in and out layers by sess.graph.get_operations()
I am thinking may be it is because of the variables defined in the network?
Hi @ddvoviyum
The "Stage Details Not Supported: VarHandleOp" error is given when you're using operations or layers that aren't yet supported. These errors can get tricky sometimes. Can you share your model and exact steps and I will try to reproduce and get back to you with results.
Sahira
Thanks for the response @Sahira_at_Intel
Here are the steps to reproduce:
Base script used:
https://github.com/tensorflow/hub/raw/master/examples/image_retraining/retrain.py
Changes made:
- Changed module to https://tfhub.dev/google/imagenet/inception_v3/feature_vector/1
- Used custom dataset of 3 classes instead of the default flower example
- Extracted final result files (checkpoints, .meta etc)
- Ran
Hi @ddvoviyum
Try enabling the debug option in the Tensorflow parser - this could provide more information about the error and which layer/operation is throwing it. You will need to set the debug flag to True in the following file as sudo:
/usr/local/bin/ncsdk/Controllers/Parsers/TensorFlow.py
Let me know what you find.
Sincerely,
Sahira
@Sahira_at_Intel
Since my last message, I have conducted my own steps as well. Following are the things I have done:
Renamed the input layer to img_input
by modifying https://github.com/tensorflow/hub/blob/master/examples/image_retraining/retrain.py#L309 to: resized_input_tensor = tf.placeholder(tf.float32, [None, height, width, 3], name="img_input")
To get information about the final model generated, I used TF's summarize_graph
which gives the following output:
Found 1 possible inputs: (name=img_input, type=float(1), shape=[?,299,299,3])
No variables spotted.
Found 1 possible outputs: (name=final_result, op=Softmax)
Found 21824117 (21.82M) const parameters, 0 (0) variable parameters, and 0 control_edges
Op types used: 490 Const, 378 Identity, 94 Conv2D, 94 FusedBatchNorm, 94 Relu, 15 ConcatV2, 9 AvgPool, 4 MaxPool, 1 Add, 1 Mean, 1 Mul, 1 Placeholder, 1 PlaceholderWithDefault, 1 MatMul, 1 Softmax, 1 Squeeze, 1 Sub
To use with tensorflow/tools/benchmark:benchmark_model try these arguments:
bazel run tensorflow/tools/benchmark:benchmark_model -- --graph=model.pb --show_flops --input_layer=img_input --input_layer_type=float --input_layer_shape=-1,299,299,3 --output_layer=final_result
Upon running mvNCCompile model.pb -in=img_input -on=final_result -o firstgraph
, following is the output:
/usr/lib/python3/dist-packages/scipy/_lib/_numpy_compat.py:10: DeprecationWarning: Importing from numpy.testing.nosetester is deprecated since 1.15.0, import from numpy.testing instead.
/usr/lib/python3/dist-packages/scipy/stats/morestats.py:16: DeprecationWarning: Importing from numpy.testing.decorators is deprecated since numpy 1.15.0, import from numpy.testing instead.
/usr/lib/python3.5/importlib/_bootstrap.py:222: RuntimeWarning: compiletime version 3.4 of module 'tensorflow.python.framework.fast_tensor_util' does not match runtime version 3.5
[Error 5] Toolkit Error: Stage Details Not Supported: Top Not Found module_apply_default/hub_input/Sub
Next, upon reading some of the threads here in the forum, I thought of giving TF's transform_graph
a try:
bazel-bin/tensorflow/tools/graph_transforms/transform_graph \
--in_graph=model.pb \
--out_graph=optimized_model.pb \
--inputs='img_input' \
--outputs='final_result' \
--transforms='
strip_unused_nodes(type=float, shape="1,299,299,3")
remove_nodes(op=Identity, op=CheckNumerics)
fold_old_batch_norms
Then I ran the compilation on this optimized model, which gave the following output:
Another interesting observation is that if I run mvNCCompile model.pb -in=input/BottleneckInputPlaceholder -on=final_result -o second.graph
I get the following:
shape: [1, 2048]
res.shape: (1, 2)
TensorFlow output shape: (1, 1, 2)
/usr/local/bin/ncsdk/Controllers/FileIO.py:65: UserWarning: You are using a large type. Consider reducing your data sizes for best performance
Blob generated
A success! However, this input layer is of a different shape, as you can see. Same success for optimized_model.pb
is also seen.
I suspect that I really need to get rid of the training steps from retrain.py
. Well, I do not know.
All these results are with debug = True
in TF parser, as you suggested.
Model: https://drive.google.com/file/d/1wHRUEOiBjx4dHBeikbMjI7A2SxEjpv60/view?usp=sharing
Thanks!
