Community support and discussions about the Intel® Distribution of OpenVINO™ toolkit, OpenCV, and all things computer vision-related on Intel® platforms.
5960 Discussions
[Error 5] Toolkit Error: Stage Details Not Supported: add
Community Manager
Hi there,
I ran the example code on ncappzoo (make run) on the machine with NCSDK Docker environment. The error message shows that [Error 5] Toolkit Error: Stage Details Not Supported: add. Is there any help? Thanks.
Yung-Sheng Lu
Community Manager
Hi @yungshenglu
Was this happening while trying to run all of the samples? Did you try running the hello_ncs_py example? This will make sure that your device is opening and closing correctly. In the meantime, I will test this on my system and get back to you.
Sahira
Community Manager
Hi @yungshenglu
update: I installed Docker on my system (my host is running Ubuntu Xenial 16.04). I installed the ncsdk inside the Docker Container and ran all the examples with make run and they ran without any errors. Please confirm that the ncsdk installed correctly on your system by running the example I mentioned above!
Sahira
