Encountering the above error attempt to compile NCS graph.
@zdrya Thank you for reporting this issue. In order to help you debug the issue, it would be helpful if you can provide a link to your model so that we may reproduce this issue on our bench. If you cannot provide the network, please try running mvNCCheck and post the results here please. Thanks.
@Tome_at_Intel I´m facing the same Error. Are there any updates on the support?
Here´s a link to the model. The model has been converted by using keras2graph.py coming from: here . I´m using the stick on Ubuntu 16.04 running on virtual box on windows 7
I met the same error in this discussion.
I convert the keras model to tensorflow model, also use the same program as @Richie86 posted.
Have anyone solved the problem?
@Richie86 @Oyakodon_he
I do not know if you can help.
The following repositories are helpful.
If you are using a model other than Yolo, please change it.
【Caution】 Keras is officially unsupported.
https://github.com/martinbel/yolo2NCS.git
Thanks to martinbel.
