6564 Discussions
Error:COREDLA_ROOT environment variable not set.Run inti_env.sh script first.
STATEABC
I am conducting an experiment according to 6.6. Programming the FPGA Device
I have run init_env.sh and setupvars.sh and other environment settings, and I can see the COREDLA_ROOT environment variable by typing env in the terminal
But when I execute the command ./build_runtime -de10_agilex in /opt/intel/fpga_ai_suite_2024.1/dla/runtime, an error still occurs:
Any help would be greatly appreciated, thank you!
Wan_Intel
Hi STATEABC,
Referring to Setting Required Environment Variables, could you please run the following command and see if the issue can be resolved?
unalias ls 2> /dev/null
source /opt/intel/openvino_2022/setupvars.sh
source /opt/intel/fpga_ai_suite_2024.1/dla/bin/init_env.sh
For more information, please refer to FPGA AI Suite Quick Start Tutorial
Wan
Wan_Intel
Hi STATEABC,
Wan
Wan_Intel
Hi STATEABC,
Thanks for your question.
This case will no longer be monitored since the issue has been resolved. If you need additional information from Intel, please submit a new question.
Wan
