6583 Discussions
Error al ejecutar los scripts de verificación de la instalación de las herramientas open vino
aesqu4
Al finalizar la instalación en un servidor ubuntu 18.04 y al realizar lo últimos pasos (los scripts de verificación para verificar la instalación
) que se puede observar en el siguiente link:
https://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_linux.html#additional-GPU-steps
Obtengo el siguiente problema
JesusE_Intel
Hi aesqu4,
Thank you for contacting Intel Customer Support. There are many factors that may cause an issue with the sample demo due to your setup in a virtual machine and Ubuntu server.
Could you follow the Get Started Guide for the Intel Neural Compute Stick 2?
The documentation lists system running Windows 10 or Ubuntu 16.04.
When using the Intel NCS 2 on a virtual machine, you will need to make sure the Virtualbox extension pack has been installed, USB 3.0 Controller is enabled and a USB filter is configured with the following information:
Name: Intel NCS 2
Vendor ID: 03e7
All other fields can stay with their default values.
Hope this helps!
Jesus
JesusE_Intel
Hi aesqu4,
Name: Intel NCS 2
Vendor ID: 03e7
Hope this helps!
Jesus
