Error occurs when using FPGA
Liu__Qiqi
I use a Mustang-F100-A10(It is based on Intel@ Arria@10 1150 GX) to test the two demos:
       demo_security_barrier_camera.sh   &   demo_squeezenet_download_convert_run.sh
I add the parameter '-d' and its value is:
       HETERO: FPGA, CPU
Then the error shows as follows:
       [ ERROR ] Standard exception from DLA library: _Map_base::at
       Error on or near line 215; exiting with status 1
So how to solve this problem?
By the way, when I set the param '-d' as:
       HETERO:CPU, FPGA
The two demos run OK, but the results is similar to that of using only CPU .
Joseph_M_Intel
I am also facing this issue. I have also verified if I switch FPGA,CPU to CPU,FPGA it appears to work but there really isn't any acceleration.
