6294 Discussions
GNA plungin: Inferring an IR (multi-input LSTM) in mode 'GNA_HW' doesn’t work
tea6329714
+ Description:
   Inferring an IR (multi-input LSTM) in mode 'GNA_HWdoesn’t work.
+ Question:
  *Q1: I can infer an IR (multi-input LSTM ) in mode ‘GNA_SW_FP32’.
           I can infer an IR (single-input LSTM ) in mode ‘GNA_HW’.
           However, I can’t infer an IR (multi-input LSTM) in mode ‘GNA_HW’.
           Can I get any chance to infer multi-input LSTM in mode ‘GNA_HW’  (python syntax)?
 *Note: LSTM-based IR are converted from pytorch.
+ Sample code: attached file
  * Requirement  packages        : VEN_requirement_date20211129.txt
  * Script 1 (infer single-input LSTM with GNA_HW):
    Issue01_OpenVINO_SingleInput_LSTMCell__GNA_HW.ipynb
  * Script 2 (infer multi-input LSTM with GNA_SW_FP32):
    Issue01_OpenVINO_MultiInput_LSTMCell__GNA_SW_FP32.ipynb
  * Script 3 (infer multi-input LSTM with GNA_HW)           :
    Issue01_OpenVINO_MultiInput_LSTMCell__GNA_HW.ipynb
  * LSTM( single-input LSTM with Pytorh framwork):
    Export_Main00\CPU_TorchModle_LSTM_CellTEST
 * LSTM( multi-input LSTM with Pytorh framwork):
    Export_Main00\CPU_TorchModle_LSTM_CellTEST_WithState
  * LSTM( single-input LSTM with ONNX framwork)  :
    Export_Main00\CPU_TraceONNX_LSTM_CellTEST.onnx
 * LSTM( multi-input LSTM with ONNX framwork)  :
    Export_Main00\CPU_TraceONNX_LSTM_CellTEST_WithState.onnx
  * LSTM(single-input LSTM with IR framwork) :
    CPU_TraceONNX_LSTM_CellTEST.xml
    CPU_TraceONNX_LSTM_CellTEST.bin
* LSTM(multi-input LSTM with IR framwork) :
    CPU_TraceONNX_LSTM_CellTEST_WithState.xml
    CPU_TraceONNX_LSTM_CellTEST_WithState.bin
+Example & Test:
  * Test 1: inferring single-input LSTM _IR with mode ‘GNA_HW’  works.
     - Input x   : A tensor with the shape [batch size :1,  time step:33,  feature bins:257].
  * Test 2: inferring multi-input LSTM _IR with mode ‘GNA_SW_FP32’  works.
     - Input x   : A tensor with the shape [batch size :1  ,  time step:33,  feature bins:257].
     - Input h0: A tensor with the shape [feature bins:257, batch size :1, feature bins:257].
     - Input c0: A tensor with the shape [feature bins:257, batch size :1, feature bins:257].
   * Test 3: inferring multi-input LSTM _IR with mode ‘GNA_HW’  didn't work.
+Result & source code of test 1:
    * Test 1 --  script & result
  * Test 2 --  script & result
    * Test 3 --  script & result
Peh_Intel
Hi tea6329714,
Thanks for sharing your findings with us.
I was able to duplicate the same issue with minimally code below:
from openvino.inference_engine import IECore
ie =IECore()
net = ie.read_network(model=<Path_xml>, weights=<Path_bin>)
new_cfg = {'GNA_DEVICE_MODE' : 'GNA_HW', 'GNA_SCALE_FACTOR’ : '1.0'}
exec_net= ie.load_network(network=net, device_name='GNA', config=new_cfg)
According to gna_config.hpp, after setting individual scale factors for all inputs, it is able to run with GNA_HW.
Input layer name: 0:0, 1:0, 2:0
Replaced codes:
new_cfg = {'GNA_DEVICE_MODE' : 'GNA_HW', 'GNA_SCALE_FACTOR_0:0' : '1.0', 'GNA_SCALE_FACTOR_1:0' : '1.0','GNA_SCALE_FACTOR_2:0' : '1.0'}
Peh
Peh_Intel
Hi tea6329714,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Peh
