6583 Discussions
How can I set deploy.prototxt using multiple input images
I tried to convert my own model to NCS version using 'mvNCCompile.pyc'.
My model has two images as inputs.
So, I wrote a prototxt as following lines.
layer {
type: "Input"
top: "A"
input_param {
shape: {
dim: 1
dim: 32
dim: 32
dim: 3
layer {
type: "Input"
top: "B"
input_param {
shape: {
dim: 1
dim: 32
dim: 32
dim: 3
However, I failed to convert the model with the following error message.
[Error 17] Toolkit Error: Internal Error: Could not build graph. Missing link: B
Could you give me a solution to use two images as input?
@sachonwon Hi I am working in this issue as well. May be it is possible to inject concatenated data and then split somehow. Let me know if you get some solution.
