Hi, I have a pre-trained inceptionv3.pb file, and convert to graph file successfully without error.
But the infer result is all NaN in python.
Debug log didn't help anything.
Start download to NCS...
D: [ 0] ncFifoWriteElem:2592 No layout conversion is needed 0
D: [ 0] convertDataTypeAndLayout:170 src data type 1 dst data type 0
D: [ 0] convertDataTypeAndLayout:172 SRC: w 299 h 299 c 3 w_s 12 h_s 3588 c_s 4
D: [ 0] convertDataTypeAndLayout:174 DST: w 299 h 299 c 3 w_s 6 h_s 1794 c_s 2
D: [ 0] ncFifoWriteElem:2617 write count 0 num_elements 2 userparam 0x7fb0fc143cd0
I: [ 0] ncGraphQueueInference:3048 trigger start
I: [ 0] ncGraphQueueInference:3145 trigger end
D: [ 0] ncFifoReadElem:2686 No layout conversion is needed 1
D: [ 0] convertDataTypeAndLayout:170 src data type 0 dst data type 1
D: [ 0] convertDataTypeAndLayout:172 SRC: w 1 h 1 c 4 w_s 8 h_s 8 c_s 2
D: [ 0] convertDataTypeAndLayout:174 DST: w 1 h 1 c 4 w_s 16 h_s 16 c_s 4
D: [ 0] ncFifoReadElem:2714 num_elements 2 userparam 0x7fb0fc143ef0 output length 16
Cost: 0.35880494117736816
output data is:
[ nan nan nan nan]
inception-v3 on NCS
[3 2 1 0]
3 3:yumi nan
2 2:tudou nan
1 1:shulin nan
0 0:huangdi nan
I don't know where to start with, someone any suggestion?
I meet the same problem too
@chenxiaoyu3 Can you provide a link to your python code?
I get almost the same error, using the same model, but with different tensor dimensions once 32 x32 in the second version 299 x 299:
D: [ 0] ncDeviceCreate:307 ncDeviceCreate index 0
D: [ 0] ncDeviceCreate:307 ncDeviceCreate index 1
1 neural compute devices found!
D: [ 0] ncDeviceOpen:523 File path /usr/local/lib/mvnc/MvNCAPI-ma2450.mvcmd
I: [ 0] ncDeviceOpen:529 ncDeviceOpen() XLinkBootRemote returned success 0
I: [ 0] ncDeviceOpen:567 XLinkConnect done - link Id 0
D: [ 0] ncDeviceOpen:581 done
I: [ 0] ncDeviceOpen:583 Booted 2-ma2450 -> VSC
I: [ 0] getDevAttributes:382 Device attributes
I: [ 0] getDevAttributes:385 Device FW version: 2.8.2450.16e
I: [ 0] getDevAttributes:387 mvTensorVersion 2.8
I: [ 0] getDevAttributes:388 Maximum graphs: 10
I: [ 0] getDevAttributes:389 Maximum fifos: 20
I: [ 0] getDevAttributes:391 Maximum graph option class: 1
I: [ 0] getDevAttributes:393 Maximum device option class: 1
I: [ 0] getDevAttributes:394 Device memory capacity: 522059056
Hello NCS! Device opened normally.
I: [ 0] ncGraphAllocate:959 Starting Graph allocation sequence
I: [ 0] ncGraphAllocate:1025 Sent graph
D: [ 0] ncGraphAllocate:1050 Graph Status 0 rc 0
D: [ 0] ncGraphAllocate:1096 Input tensor w 299 h 299 c 3 n 1 totalSize 536406 wstide 6 hstride 1794 cstride 2 layout 0
D: [ 0] ncGraphAllocate:1109 output tensor w 1 h 1 c 2 n 1 totalSize 4 wstide 4 hstride 4 cstride 2 layout 1
I: [ 0] ncGraphAllocate:1163 Graph allocation completed successfully
I: [ 0] ncFifoCreate:2163 Init fifo
I: [ 0] ncFifoAllocate:2358 Creating fifo
D: [ 0] ncFifoWriteElem:2629 No layout conversion is needed 0
D: [ 0] convertDataTypeAndLayout:169 src data type 1 dst data type 0
D: [ 0] convertDataTypeAndLayout:171 SRC: w 299 h 299 c 3 w_s 12 h_s 3588 c_s 4
D: [ 0] convertDataTypeAndLayout:173 DST: w 299 h 299 c 3 w_s 6 h_s 1794 c_s 2
D: [ 0] ncFifoWriteElem:2654 write count 0 num_elements 2 userparam 0x7f4fe3040d58
I: [ 0] ncGraphQueueInference:3089 trigger start
I: [ 0] ncGraphQueueInference:3186 trigger end
E: [ 0] dispatcherEventReceive:235 dispatcherEventReceive() Read failed -1
E: [ 0] eventReader:253 Failed to receive event, the device may have reset
E: [ 0] ncFifoReadElem:2735 Failed to read fifo element
