Hello, I'm trying to enable Intel VAAPI on OPENCV because I want to make fast video playback using OPENCV in an embedded environment ( Currently, I'm using a LattePanda board) but `Videocapture()` and `imshow()` processing are very slow.
To alleviate this problem, Although I used multithreading, It was not enough for the original fps.
Therefore, I thought that the method to make playback of the original fps is using Intel graphics acceleration.
So, please tell me how could I make intel VAAPI based OPENCV ?
CMAKE command I used like that:
cmake -D CMAKE_BUILD_TYPE=RELEASE -D CMAKE_INSTALL_PREFIX=/usr/local -D WITH_TBB=ON -D BUILD_NEW_PYTHON_SUPPORT=ON -D WITH_V4L=ON -D INSTALL_C_EXAMPLES=ON -D INSTALL_PYTHON_EXAMPLES=ON -D BUILD_EXAMPLES=ON -D WITH_QT=ON -D WITH_OPENGL=ON -D WITH_GSTREAMER=ON -D WITH_FFMPEG=ON -D WITH_VA_INTEL ..
My OPNECV cmake result is like that:
-- Looking for ccache - not found -- Found ZLIB: /usr/lib/x86_64-linux-gnu/libz.so (found suitable version "1.2.8", minimum required is "1.2.3") -- Found ZLIB: /usr/lib/x86_64-linux-gnu/libz.so (found version "1.2.8") -- Found OpenEXR: /usr/lib/x86_64-linux-gnu/libIlmImf.so -- WARNING: Can't build ffmpeg test code and this is for testing by Gibeom Song CMake Warning at cmake/OpenCVFindVA_INTEL.cmake:29 (message): Intel OpenCL installation is not found. Call Stack (most recent call first): cmake/OpenCVFindLibsVideo.cmake:46 (include) CMakeLists.txt:772 (include) -- Found TBB (env): /usr/lib/x86_64-linux-gnu/libtbb.so -- found Intel IPP (ICV version): 2019.0.0 [2019.0.0 Gold] -- at: /home/admin/work/opencv/build/3rdparty/ippicv/ippicv_lnx/icv -- found Intel IPP Integration Wrappers sources: 2019.0.0 -- at: /home/admin/work/opencv/build/3rdparty/ippicv/ippicv_lnx/iw -- Could not find OpenBLAS include. Turning OpenBLAS_FOUND off -- Could not find OpenBLAS lib. Turning OpenBLAS_FOUND off -- Could NOT find Atlas (missing: Atlas_CBLAS_INCLUDE_DIR Atlas_CLAPACK_INCLUDE_DIR Atlas_CBLAS_LIBRARY Atlas_BLAS_LIBRARY Atlas_LAPACK_LIBRARY) -- A library with BLAS API not found. Please specify library location. -- LAPACK requires BLAS -- A library with LAPACK API not found. Please specify library location. -- Could NOT find JNI (missing: JAVA_AWT_LIBRARY JAVA_JVM_LIBRARY JAVA_INCLUDE_PATH JAVA_INCLUDE_PATH2 JAVA_AWT_INCLUDE_PATH) -- Could NOT find Pylint (missing: PYLINT_EXECUTABLE) -- Could NOT find Flake8 (missing: FLAKE8_EXECUTABLE) -- VTK is not found. Please set -DVTK_DIR in CMake to VTK build directory, or to VTK install subdirectory with VTKConfig.cmake file -- OpenCV Python: during development append to PYTHONPATH: /home/admin/work/opencv/build/python_loader -- WARNING: Can't build ffmpeg test code -- OpenCL samples are skipped: OpenCL SDK is required -- -- General configuration for OpenCV 4.1.0-dev ===================================== -- Version control: 4.1.0-59-g8af9624-dirty -- -- Platform: -- Timestamp: 2019-04-22T07:02:02Z -- Host: Linux 4.12.1-20180417 x86_64 -- CMake: 3.5.1 -- CMake generator: Unix Makefiles -- CMake build tool: /usr/bin/make -- Configuration: RELEASE -- -- CPU/HW features: -- Baseline: SSE SSE2 SSE3 -- requested: SSE3 -- Dispatched code generation: SSE4_1 SSE4_2 FP16 AVX AVX2 AVX512_SKX -- requested: SSE4_1 SSE4_2 AVX FP16 AVX2 AVX512_SKX -- SSE4_1 (15 files): + SSSE3 SSE4_1 -- SSE4_2 (2 files): + SSSE3 SSE4_1 POPCNT SSE4_2 -- FP16 (1 files): + SSSE3 SSE4_1 POPCNT SSE4_2 FP16 AVX -- AVX (5 files): + SSSE3 SSE4_1 POPCNT SSE4_2 AVX -- AVX2 (29 files): + SSSE3 SSE4_1 POPCNT SSE4_2 FP16 FMA3 AVX AVX2 -- AVX512_SKX (2 files): + SSSE3 SSE4_1 POPCNT SSE4_2 FP16 FMA3 AVX AVX2 AVX_512F AVX512_SKX -- -- C/C++: -- Built as dynamic libs?: YES -- C++ Compiler: /usr/bin/c++ (ver 5.4.0) -- C++ flags (Release): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wno-delete-non-virtual-dtor -Wno-comment -fdiagnostics-show-option -Wno-long-long -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -msse -msse2 -msse3 -fvisibility=hidden -fvisibility-inlines-hidden -O3 -DNDEBUG -DNDEBUG -- C++ flags (Debug): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wno-delete-non-virtual-dtor -Wno-comment -fdiagnostics-show-option -Wno-long-long -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -msse -msse2 -msse3 -fvisibility=hidden -fvisibility-inlines-hidden -g -O0 -DDEBUG -D_DEBUG -- C Compiler: /usr/bin/cc -- C flags (Release): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-comment -fdiagnostics-show-option -Wno-long-long -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -msse -msse2 -msse3 -fvisibility=hidden -O3 -DNDEBUG -DNDEBUG -- C flags (Debug): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-comment -fdiagnostics-show-option -Wno-long-long -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -msse -msse2 -msse3 -fvisibility=hidden -g -O0 -DDEBUG -D_DEBUG -- Linker flags (Release): -Wl,--gc-sections -- Linker flags (Debug): -Wl,--gc-sections -- ccache: NO -- Precompiled headers: YES -- Extra dependencies: dl m pthread rt /usr/lib/x86_64-linux-gnu/libGLU.so /usr/lib/x86_64-linux-gnu/libGL.so -- 3rdparty dependencies: -- -- OpenCV modules: -- To be built: calib3d core dnn features2d flann gapi highgui imgcodecs imgproc ml objdetect photo python2 stitching ts video videoio -- Disabled: world -- Disabled by dependency: - -- Unavailable: java js python3 -- Applications: tests perf_tests examples apps -- Documentation: NO -- Non-free algorithms: NO -- -- GUI: -- QT: YES (ver 5.5.1) -- QT OpenGL support: YES (Qt5::OpenGL 5.5.1) -- GTK+: NO -- OpenGL support: YES (/usr/lib/x86_64-linux-gnu/libGLU.so /usr/lib/x86_64-linux-gnu/libGL.so) -- VTK support: NO -- -- Media I/O: -- ZLib: /usr/lib/x86_64-linux-gnu/libz.so (ver 1.2.8) -- JPEG: /usr/lib/x86_64-linux-gnu/libjpeg.so (ver 80) -- WEBP: build (ver encoder: 0x020e) -- PNG: /usr/lib/x86_64-linux-gnu/libpng.so (ver 1.2.54) -- TIFF: /usr/lib/x86_64-linux-gnu/libtiff.so (ver 42 / 4.0.6) -- JPEG 2000: /usr/lib/x86_64-linux-gnu/libjasper.so (ver 1.900.1) -- OpenEXR: /usr/lib/x86_64-linux-gnu/libImath.so /usr/lib/x86_64-linux-gnu/libIlmImf.so /usr/lib/x86_64-linux-gnu/libIex.so /usr/lib/x86_64-linux-gnu/libHalf.so /usr/lib/x86_64-linux-gnu/libIlmThread.so (ver 2.2.0) -- HDR: YES -- SUNRASTER: YES -- PXM: YES -- PFM: YES -- -- Video I/O: -- DC1394: YES (2.2.4) -- FFMPEG: NO -- avcodec: YES (56.60.100) -- avformat: YES (56.40.101) -- avutil: YES (54.31.100) -- swscale: YES (3.1.101) -- avresample: YES (2.1.0) -- GStreamer: YES (1.8.3) -- v4l/v4l2: YES (linux/videodev2.h) -- -- Parallel framework: TBB (ver 4.4 interface 9002) -- -- Trace: YES (with Intel ITT) -- -- Other third-party libraries: -- Intel IPP: 2019.0.0 Gold [2019.0.0] -- at: /home/admin/work/opencv/build/3rdparty/ippicv/ippicv_lnx/icv -- Intel IPP IW: sources (2019.0.0) -- at: /home/admin/work/opencv/build/3rdparty/ippicv/ippicv_lnx/iw -- VA: YES -- Intel VA-API/OpenCL: NO -- Lapack: NO -- Eigen: NO -- Custom HAL: NO -- Protobuf: build (3.5.1) -- -- OpenCL: YES (no extra features) -- Include path: /home/admin/work/opencv/3rdparty/include/opencl/1.2 -- Link libraries: Dynamic load -- -- Python 2: -- Interpreter: /usr/bin/python2.7 (ver 2.7.12) -- Libraries: /usr/lib/x86_64-linux-gnu/libpython2.7.so (ver 2.7.12) -- numpy: /usr/lib/python2.7/dist-packages/numpy/core/include (ver 1.11.0) -- install path: lib/python2.7/dist-packages/cv2/python-2.7 -- -- Python (for build): /usr/bin/python2.7 -- -- Java: -- ant: NO -- JNI: NO -- Java wrappers: NO -- Java tests: NO -- -- Install to: /usr/local -- ----------------------------------------------------------------- -- -- Configuring done -- Generating done -- Build files have been written to: /home/admin/work/opencv/build
Hi Gibeom,
as this is an OpenCV related question, you should post your question on the OpenCV forum: https://answers.opencv.org/questions/
Best,
Severine
Okay, I see
Thank you
Try to use GStreamer videoio backend with VA-API GStreamer plugin, you can find some examples here: https://github.com/opencv/opencv/wiki/Video-capture-and-write-benchmark
Hi Maksim,
Although I tried GStreamer as the backend of OPNECV using this code below, It is looked to be not working.
This code display very slow and grayscale frame.
cap = cv2.VideoCapture("filesrc location=test.mp4 ! qtdemux ! vaapidecodebin ! appsink")
And then, vaapi that I used is not dependent with Intel MediaSDK. It depends only on libva-intel-driver(i965).
However, I don't know that i965 vaapi could be compatible with OPENCV. If i965 vaapi couldn't be compatible with OPENCV, houw could I get another approach to make video decoding acceleration based video playback?
i965 driver is OK, check that "vainfo" command works and produces meaningful output. Try to run similar gstreamer pipelines using standalone gst-launch tool: "gst-launch-1.0 filesrc location=... ! decodebin ! fakesink". Try to add "sync=false" parameter to the sink element: "... ! appsink sync=false". Try to measure time spent in each part of your pipeline, for example by using cv::TickMeter class. Try to use video file with lower resolution or different codec.
OpenCV does not use libva for decoding directly, it can be used via GStreamer or MediaSDK videoio backend. Build option "WITH_INTEL_VA" enables OpenCL-VAAPI interoperability which does not help with decoding.
Hi Maksim, and really appreciate to you.
my vainfo command result is like that:
root@lattepanda:~/Development/python# vainfo error: XDG_RUNTIME_DIR not set in the environment. libva info: VA-API version 0.39.0 libva info: va_getDriverName() returns 0 libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/i965_drv_video.so libva info: Found init function __vaDriverInit_0_39 libva info: va_openDriver() returns 0 vainfo: VA-API version: 0.39 (libva 1.7.0) vainfo: Driver version: Intel i965 driver for Intel(R) CherryView - 1.7.0 vainfo: Supported profile and entrypoints VAProfileMPEG2Simple : VAEntrypointVLD VAProfileMPEG2Simple : VAEntrypointEncSlice VAProfileMPEG2Main : VAEntrypointVLD VAProfileMPEG2Main : VAEntrypointEncSlice VAProfileH264ConstrainedBaseline: VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice VAProfileH264Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointEncSlice VAProfileH264High : VAEntrypointVLD VAProfileH264High : VAEntrypointEncSlice VAProfileH264MultiviewHigh : VAEntrypointVLD VAProfileH264MultiviewHigh : VAEntrypointEncSlice VAProfileH264StereoHigh : VAEntrypointVLD VAProfileH264StereoHigh : VAEntrypointEncSlice VAProfileVC1Simple : VAEntrypointVLD VAProfileVC1Main : VAEntrypointVLD VAProfileVC1Advanced : VAEntrypointVLD VAProfileNone : VAEntrypointVideoProc VAProfileJPEGBaseline : VAEntrypointVLD VAProfileJPEGBaseline : VAEntrypointEncPicture VAProfileVP8Version0_3 : VAEntrypointVLD VAProfileVP8Version0_3 : VAEntrypointEncSlice VAProfileHEVCMain : VAEntrypointVLD
And then opencv build information of python is like that:
root@lattepanda:~/Development/python# python Buildinfo.py General configuration for OpenCV 4.1.0-dev ===================================== Version control: 4.1.0-84-gf5801ee Platform: Timestamp: 2019-04-30T13:36:12Z Host: Linux 4.12.1-20180417 x86_64 CMake: 3.5.1 CMake generator: Unix Makefiles CMake build tool: /usr/bin/make Configuration: RELEASE CPU/HW features: Baseline: SSE SSE2 SSE3 requested: SSE3 Dispatched code generation: SSE4_1 SSE4_2 FP16 AVX AVX2 AVX512_SKX requested: SSE4_1 SSE4_2 AVX FP16 AVX2 AVX512_SKX SSE4_1 (15 files): + SSSE3 SSE4_1 SSE4_2 (2 files): + SSSE3 SSE4_1 POPCNT SSE4_2 FP16 (1 files): + SSSE3 SSE4_1 POPCNT SSE4_2 FP16 AVX AVX (5 files): + SSSE3 SSE4_1 POPCNT SSE4_2 AVX AVX2 (29 files): + SSSE3 SSE4_1 POPCNT SSE4_2 FP16 FMA3 AVX AVX2 AVX512_SKX (2 files): + SSSE3 SSE4_1 POPCNT SSE4_2 FP16 FMA3 AVX AVX2 AVX_512F AVX512_SKX C/C++: Built as dynamic libs?: YES C++ Compiler: /usr/bin/c++ (ver 5.4.0) C++ flags (Release): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wno-delete-non-virtual-dtor -Wno-comment -fdiagnostics-show-option -Wno-long-long -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -msse -msse2 -msse3 -fvisibility=hidden -fvisibility-inlines-hidden -O3 -DNDEBUG -DNDEBUG C++ flags (Debug): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wno-delete-non-virtual-dtor -Wno-comment -fdiagnostics-show-option -Wno-long-long -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -msse -msse2 -msse3 -fvisibility=hidden -fvisibility-inlines-hidden -g -O0 -DDEBUG -D_DEBUG C Compiler: /usr/bin/cc C flags (Release): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-comment -fdiagnostics-show-option -Wno-long-long -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -msse -msse2 -msse3 -fvisibility=hidden -O3 -DNDEBUG -DNDEBUG C flags (Debug): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-comment -fdiagnostics-show-option -Wno-long-long -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -msse -msse2 -msse3 -fvisibility=hidden -g -O0 -DDEBUG -D_DEBUG Linker flags (Release): -Wl,--gc-sections Linker flags (Debug): -Wl,--gc-sections ccache: NO Precompiled headers: YES Extra dependencies: dl m pthread rt /usr/lib/x86_64-linux-gnu/libGLU.so /usr/lib/x86_64-linux-gnu/libGL.so 3rdparty dependencies: OpenCV modules: To be built: calib3d core dnn features2d flann gapi highgui imgcodecs imgproc ml objdetect photo python2 stitching ts video videoio Disabled: world Disabled by dependency: - Unavailable: java js python3 Applications: tests perf_tests examples apps Documentation: NO Non-free algorithms: NO GUI: QT: YES (ver 4.8.7 EDITION = OpenSource) QT OpenGL support: YES (/usr/lib/x86_64-linux-gnu/libQtOpenGL.so) GTK+: NO OpenGL support: YES (/usr/lib/x86_64-linux-gnu/libGLU.so /usr/lib/x86_64-linux-gnu/libGL.so) VTK support: NO Media I/O: ZLib: /usr/lib/x86_64-linux-gnu/libz.so (ver 1.2.8) JPEG: /usr/lib/x86_64-linux-gnu/libjpeg.so (ver 80) WEBP: build (ver encoder: 0x020e) PNG: /usr/lib/x86_64-linux-gnu/libpng.so (ver 1.2.54) TIFF: /usr/lib/x86_64-linux-gnu/libtiff.so (ver 42 / 4.0.6) JPEG 2000: /usr/lib/x86_64-linux-gnu/libjasper.so (ver 1.900.1) OpenEXR: /usr/lib/x86_64-linux-gnu/libImath.so /usr/lib/x86_64-linux-gnu/libIlmImf.so /usr/lib/x86_64-linux-gnu/libIex.so /usr/lib/x86_64-linux-gnu/libHalf.so /usr/lib/x86_64-linux-gnu/libIlmThread.so (ver 2.2.0) HDR: YES SUNRASTER: YES PXM: YES PFM: YES Video I/O: DC1394: YES (2.2.4) FFMPEG: YES avcodec: YES (58.52.100) avformat: YES (58.27.103) avutil: YES (56.26.100) swscale: YES (5.4.100) avresample: NO GStreamer: YES (1.8.3) v4l/v4l2: YES (linux/videodev2.h) Parallel framework: TBB (ver 4.4 interface 9002) Trace: YES (with Intel ITT) Other third-party libraries: Intel IPP: 2019.0.0 Gold [2019.0.0] at: /home/admin/work/opencv/build/3rdparty/ippicv/ippicv_lnx/icv Intel IPP IW: sources (2019.0.0) at: /home/admin/work/opencv/build/3rdparty/ippicv/ippicv_lnx/iw VA: NO Lapack: NO Eigen: NO Custom HAL: NO Protobuf: build (3.5.1) OpenCL: YES (no extra features) Include path: /home/admin/work/opencv/3rdparty/include/opencl/1.2 Link libraries: Dynamic load Python 2: Interpreter: /usr/bin/python2.7 (ver 2.7.12) Libraries: /usr/lib/x86_64-linux-gnu/libpython2.7.so (ver 2.7.12) numpy: /usr/lib/python2.7/dist-packages/numpy/core/include (ver 1.11.0) install path: lib/python2.7/dist-packages/cv2/python-2.7 Python (for build): /usr/bin/python2.7 Java: ant: NO JNI: NO Java wrappers: NO Java tests: NO Install to: /usr/local -----------------------------------------------------------------
As your advice, I tried to execute some case using standalone gst-launch and OPENCV with GStreamer on python.
gst-launch-1.0 filesrc location=1.mp4 ! qtdemux ! vaapidecodebin ! vaapisink
root@lattepanda:~/Development/python# gst-launch-1.0 filesrc location=1.mp4 ! qtdemux ! vaapidecodebin ! vaapisink error: XDG_RUNTIME_DIR not set in the environment. libva info: VA-API version 0.39.0 libva info: va_getDriverName() returns 0 libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/i965_drv_video.so libva info: Found init function __vaDriverInit_0_39 libva info: va_openDriver() returns 0 Setting pipeline to PAUSED ... Pipeline is PREROLLING ... Got context from element 'pipeline0': gst.vaapi.Display=context, gst.vaapi.Display=(GstVaapiDisplay)NULL; Redistribute latency... Redistribute latency... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Got EOS from element "pipeline0". Execution ended after 0:00:15.048737675 Setting pipeline to PAUSED ... Setting pipeline to READY ... Setting pipeline to NULL ... Freeing pipeline ...
Above command works very well. I think that this command use vaapi (i965).
root@lattepanda:~/Development/python# gst-launch-1.0 filesrc location=1.mp4 ! qtdemux ! vaapidecodebin ! fakesink Setting pipeline to PAUSED ... error: XDG_RUNTIME_DIR not set in the environment. libva info: VA-API version 0.39.0 libva info: va_getDriverName() returns 0 libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/i965_drv_video.so libva info: Found init function __vaDriverInit_0_39 libva info: va_openDriver() returns 0 Pipeline is PREROLLING ... Got context from element 'vaapidecode': gst.vaapi.Display=context, gst.vaapi.Display=(GstVaapiDisplay)NULL; Redistribute latency... Redistribute latency... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Got EOS from element "pipeline0". Execution ended after 0:00:01.447928856 Setting pipeline to PAUSED ... Setting pipeline to READY ... Setting pipeline to NULL ... Freeing pipeline ...
I don't know that the above command worked correctly.
Finally, I executed this python script.
import numpy as np import cv2 cap = cv2.VideoCapture('gst-launch-1.0 filesrc location=1.mp4 ! qtdemux ! vaapidecodebin ! appsink sync=false ', cv2.CAP_GSTREAMER) while(True): ret, frame = cap.read() cv2.imshow('frame',frame) if cv2.waitKey(1) & 0xFF == ord('q'): break cap.release() cv2.destroyAllWindows()
But the above python script still displays frame slowly.
I don't know whether I used GStreamer through python correctly. Is this try correct?
There should be no "gst-launch-1.0" in VideoCapture constructor, are you sure you run the script you've posted? The processing via OpenCV can be slower than via gst-launch because there are additional copying and converting on the OpenCV side (CPU). This transition can be emulated by using "gtksink" or similar element instead of "vaapisink".
So far I can only recommend experimenting with different pipelines and measuring performance of decoding (cap.read) and drawing (imshow).
Hint: you can find all parameters of gstreamer element by running "gst-inspect-1.0 <element>" command, e.g. "gst-inspect-1.0 vaapidecodebin".
Hello,i see TBB version in your Cmake outputs:
Can you tell me how do you do this? Well, i am compiling opencv4.1.0 with TBB supporting on Ubuntu 16.04 which means I have clicked "BUILD_TBB" and "With_TBB" in Cmake. However, my outputs are like:
Parallel framework: TBB (ver . interface)
There is no version information and "TBB_VER_FILE_NOTFOUND" appears. In the other side, there are error outputs like:
CMake Error at 3rdparty/tbb/CMakeLists.txt:102 (add_library):
Cannot find source file:
/home/jumper/forcv/opencv-4.1.0/buildcv/3rdparty/tbb/tbb-2018_U1/src/rml/client/rml_tbb.cpp
Tried extensions .c .C .c++ .cc .cpp .cxx .m .M .mm .h .hh .h++ .hm .hpp
.hxx .in .txx
CMake Error: CMake can not determine linker language for target: tbb
CMake Error in 3rdparty/tbb/CMakeLists.txt:
Exporting the target "tbb" is not allowed since its linker language cannot
be determined
Can you tell me the reason causing this even though i have installed TBB in advance:
-- apt-get install libtbb-dev
