6551 Discussions
How to train "ncappzoo/apps/dogsvscats" W/ the CPU-only caffe ???
Hi all,
I am re-build the follow blog trial and found is used W/ a GPU-caffe. But I install the CPU-only caffe. Could I adjust some settings to fix this problem ? https://movidius.github.io/blog/deploying-custom-caffe-models/
root@ubuntu:~/workspace/ncappzoo/apps/dogsvscats# ls
AUTHORS.txt create-labels.py data README.md
bvlc_googlenet create-lmdb.sh Makefile
root@ubuntu:~/workspace/ncappzoo/apps/dogsvscats# $CAFFE_PATH/build/tools/caffe train --solver bvlc_googlenet/org/solver.prototxt --weights $CAFFE_PATH/models/bvlc_googlenet/bvlc_googlenet.caffemodel 2>&1 | tee bvlc_googlenet/org/train.log
bash: /build/tools/caffe: No such file or directory
root@ubuntu:~/workspace/ncappzoo/apps/dogsvscats# If everything went well, you should see a bunch of .caffemodel and .solverstate files in the
If: command not found
root@ubuntu:~/workspace/ncappzoo/apps/dogsvscats# export CAFFE_PATH=/root/caffe
root@ubuntu:~/workspace/ncappzoo/apps/dogsvscats# $CAFFE_PATH/scripts/download_model_binary.py $CAFFE_PATH/models/bvlc_googlenet
Model already exists.
I0325 20:20:51.785151 2685 caffe.cpp:204] Using GPUs 0
F0325 20:20:51.785328 2685 common.cpp:66] Cannot use GPU in CPU-only Caffe: check mode.
*** Check failure stack trace: ***
@ 0x7f591ed5de3d google::LogMessage::Fail()
@ 0x7f591ed5fbc0 google::LogMessage::SendToLog()
@ 0x7f591ed5da23 google::LogMessage::Flush()
@ 0x7f591ed6058e google::LogMessageFatal::~LogMessageFatal()
@ 0x7f591f28fd00 caffe::Caffe::SetDevice()
@ 0x40a61b train()
@ 0x407010 main
@ 0x7f591deee830 (unknown)
@ 0x407969 _start
BRs,
@ideallyworld
This problem has been fixed by adjusted the solver.prototxtsolver.prototxt :
last line "GPU" change to "CPU"
Now closed this problem.
