6597 Discussions
I want to use 2 x Myriad X (NCS2) chips in one application by using OpenVINO
ABoch5
I want to create application that uses 2 x MyriadX chips simultaneously in one application, for alternating frames.
I use existing C++ sample "object_detection_demo_yolov3_async" of Yolov3 object detection.
I changed this code to use 2 Networks instead of 1.
And pressed TAB to use existing Async mode therefore, the application alternately starts two InferRequest::Ptr's belonging to different networks and waits for them.
I tried both frozen_yolov3.pb and frozen_yolov3_tiny.pb, but it doesn't increase FPS.
I changed this code: https://github.com/opencv/open_model_zoo/blob/e458c1f0407d0303e36be4828bb963a67d6d050a/demos/object_detection_demo_yolov3_async/main.cpp#L287-L293
ExecutableNetwork network = plugin.LoadNetwork(netReader.getNetwork(), {});   // -----------------------------------------------------------------------------------------------------   // --------------------------- 5. Creating infer request ----------------------------------------------- InferRequest::Ptr async_infer_request_next = network.CreateInferRequestPtr(); InferRequest::Ptr async_infer_request_curr = network.CreateInferRequestPtr();
to this code:
ExecutableNetwork network = plugin.LoadNetwork(netReader.getNetwork(), {}); ExecutableNetwork network2 = plugin.LoadNetwork(netReader.getNetwork(), {});   // -----------------------------------------------------------------------------------------------------   // --------------------------- 5. Creating infer request ----------------------------------------------- InferRequest::Ptr async_infer_request_next = network2.CreateInferRequestPtr(); InferRequest::Ptr async_infer_request_curr = network.CreateInferRequestPtr();
Then run application object_detection_demo_yolov3_async and press TAB for async execution.
But it did not speed up the execution.
How can I see usage (in %) for each VPU?
I actually have 2 x MyriadX chips:
Aroop_B_Intel
Hi ABoch5,
Take a look at the Multiple NCS Devices section in the following article for a high-level explanation on using multiple NCS devices within your application.
https://software.intel.com/en-us/articles/transitioning-from-intel-movidius-neural-compute-sdk-to-openvino-toolkit
There is also a discussion on this subject on the computer vision forum. Pinto shared his GitHub where he is running inference with multiple NCS to improve performance of his YOLO V3 model.
https://software.intel.com/en-us/forums/computer-vision/topic/801648
https://github.com/PINTO0309/OpenVINO-YoloV3
The OpenVINO toolkit does not have the capability to display the VPU usage.
Aroop
