6574 Discussions
Install prerequisite numpy version conflicts
bingol__evren
I get this error
ERROR: tensorflow 1.15.0 has requirement numpy<2.0,>=1.16.0, but you'll have numpy 1.15.0 which is incompatible.
ERROR: mxnet 1.3.1 has requirement numpy<1.15.0,>=1.8.2, but you'll have numpy 1.15.0 which is incompatible.
When I upgrate to latest numby tensorflow error goes away
and I am only left with :
WHen I down grade the the version mxnet wants tensorflow complains.
It is sort of a chicken and egg situation
Am I missing anything.
Cary_P_Intel1
Hi, Evren,
Yes, the required library for different framework might conflict with each other due to numpy version used. Do you use both of the framework at the same time? currently the workaround might need to change the numpy version base on the AI framework you are using or about to converted by Model Optimizer.
