I'm trying to convert a Tensorflow model into IR. The model Mask RCNN Inception V2 and I didn't modify it. After running MO I receive the following output:
[ ERROR ] ----------------- INTERNAL ERROR ----------------
[ ERROR ] Unexpected exception happened.
[ ERROR ] Please contact Model Optimizer developers and forward the following information:
[ ERROR ] 0
[ ERROR ] Traceback (most recent call last):
File "C:\Intel\computer_vision_sdk_2018.3.343\deployment_tools\model_optimizer\mo\main.py", line 321, in main
return driver(argv)
File "C:\Intel\computer_vision_sdk_2018.3.343\deployment_tools\model_optimizer\mo\main.py", line 263, in driver
mean_scale_values=mean_scale)
File "C:\Intel\computer_vision_sdk_2018.3.343\deployment_tools\model_optimizer\mo\pipeline\tf.py", line 171, in
tf2nx
class_registration.apply_replacements(graph, class_registration.ClassType.FRONT_REPLACER)
File "C:\Intel\computer_vision_sdk_2018.3.343\deployment_tools\model_optimizer\mo\utils\class_registration.py",
line 102, in apply_replacements
replacer.find_and_replace_pattern(graph)
File "C:\Intel\computer_vision_sdk_2018.3.343\deployment_tools\model_optimizer\mo\front\tf\replacement.py", lin
e 50, in find_and_replace_pattern
self.transform_graph(graph, desc._replacement_desc['custom_attributes'])
File "C:\Intel\computer_vision_sdk_2018.3.343\deployment_tools\model_optimizer\extensions\front\tf\ObjectDetect
ionAPI.py", line 359, in transform_graph
last_node = Node(graph, op_output).in_node(0)
File "C:\Intel\computer_vision_sdk_2018.3.343\deployment_tools\model_optimizer\mo\graph\graph.py", line 267, in
in_node
return self.in_nodes()[key]
KeyError: 0
[ ERROR ] ---------------- END OF BUG REPORT --------------
[ ERROR ] -------------------------------------------------
The command used is below:
python ./mo_tf.py --input_model=C:\downloads\mask_rcnn_inception_v2_coco_2018_01_28.tar\mask_rcnn_inception_v2_coco_2018_01_28\frozen_inference_graph.pb --tensorflow_use_custom_operations_config C:\Intel\computer_vision_sdk_2018.3.343\deployment_tools\model_optimizer\extensions\front\tf\mask_rcnn_support.json --output="num_detections,detection_masks,detection_boxes,detection_classes,detection_scores" --tensorflow_object_detection_api_pipeline_config C:\downloads\mask_rcnn_inception_v2_coco_2018_01_28.tar\mask_rcnn_inception_v2_coco_2018_01_28\pipeline.config
Dear Mikhail,
it is the argument --output="num_detections,detection_masks,detection_boxes,detection_classes,detection_scores" which breaks the conversion, withdraw it and it will work.
Best,
Severine
Topic Options
