Is NSC2 compatible with Vision processing Units (VPU)
Lee__Terry
I have a system that is currently using NSC2. Can I use Vision Processing Units (VPU) instead.
If they are compatible,  is there any software changes that I need to do ?
Terry
SuryaPSC_Intel
Hi Lee, Terry,
You can use Intel® Movidius™ VPU in place of NCS2 by changing the target device to HDDL.
As seen from the demo, same code can be used with either of the devices.
Please confirm that you have followed the instructions to setup Intel® Movidius™ VPU for use with Intel® Distribution of OpenVINO™ toolkit
Also verify the installation by running the verification scripts for Windows or Linux.
Feel free to ask any other questions.
Surya
Lee__Terry
Sounds good. Thanks Surya.
