(base) dhanu@myVM:~$ python3 /opt/intel/openvino_2020.2.120/deployment_tools/model_optimizer/mo_tf.py --input_model /home/dhanu/Downloads/model4_256/output/graph.pbtxt --input "IteratorGetNext:0[16 256],IteratorGetNext:1[16 256],IteratorGetNext:2[16],IteratorGetNext:3[16 10],IteratorGetNext:4[16 256]" --input_model_is_text --disable_nhwc_to_nchw --keep_shape_ops
Model Optimizer arguments:
Common parameters:
- Path to the Input Model: /home/dhanu/Downloads/model4_256/output/graph.pbtxt
- Path for generated IR: /home/dhanu/.
- IR output name: graph
- Log level: ERROR
- Batch: Not specified, inherited from the model
- Input layers: IteratorGetNext:0[16 256],IteratorGetNext:1[16 256],IteratorGetNext:2[16],IteratorGetNext:3[16 10],IteratorGetNext:4[16 256]
- Output layers: Not specified, inherited from the model
- Input shapes: Not specified, inherited from the model
- Mean values: Not specified
- Scale values: Not specified
- Scale factor: Not specified
- Precision of IR: FP32
- Enable fusing: True
- Enable grouped convolutions fusing: True
- Move mean values to preprocess section: False
- Reverse input channels: False
TensorFlow specific parameters:
- Input model in text protobuf format: True
- Path to model dump for TensorBoard: None
- List of shared libraries with TensorFlow custom layers implementation: None
- Update the configuration file with input/output node names: None
- Use configuration file used to generate the model with Object Detection API: None
- Use the config file: None
Model Optimizer version: 2020.2.0-60-g0bc66e26ff
/home/dhanu/anaconda3/lib/python3.7/site-packages/tensorflow/python/framework/dtypes.py:516: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
_np_qint8 = np.dtype([("qint8", np.int8, 1)])
/home/dhanu/anaconda3/lib/python3.7/site-packages/tensorflow/python/framework/dtypes.py:517: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
_np_quint8 = np.dtype([("quint8", np.uint8, 1)])
/home/dhanu/anaconda3/lib/python3.7/site-packages/tensorflow/python/framework/dtypes.py:518: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
_np_qint16 = np.dtype([("qint16", np.int16, 1)])
/home/dhanu/anaconda3/lib/python3.7/site-packages/tensorflow/python/framework/dtypes.py:519: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
_np_quint16 = np.dtype([("quint16", np.uint16, 1)])
/home/dhanu/anaconda3/lib/python3.7/site-packages/tensorflow/python/framework/dtypes.py:520: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
_np_qint32 = np.dtype([("qint32", np.int32, 1)])
/home/dhanu/anaconda3/lib/python3.7/site-packages/tensorflow/python/framework/dtypes.py:525: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
np_resource = np.dtype([("resource", np.ubyte, 1)])
/home/dhanu/anaconda3/lib/python3.7/site-packages/tensorboard/compat/tensorflow_stub/dtypes.py:541: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/home/dhanu/anaconda3/lib/python3.7/site-packages/tensorboard/compat/tensorflow_stub/dtypes.py:542: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/home/dhanu/anaconda3/lib/python3.7/site-packages/tensorboard/compat/tensorflow_stub/dtypes.py:543: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/home/dhanu/anaconda3/lib/python3.7/site-packages/tensorboard/compat/tensorflow_stub/dtypes.py:544: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/home/dhanu/anaconda3/lib/python3.7/site-packages/tensorboard/compat/tensorflow_stub/dtypes.py:545: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/home/dhanu/anaconda3/lib/python3.7/site-packages/tensorboard/compat/tensorflow_stub/dtypes.py:550: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
[ ERROR ] -------------------------------------------------
[ ERROR ] ----------------- INTERNAL ERROR ----------------
[ ERROR ] Unexpected exception happened.
[ ERROR ] Please contact Model Optimizer developers and forward the following information:
[ ERROR ] Exception occurred during running replacer "None (<class 'extensions.front.no_op_eraser.NoOpEraser'>)": The node group_deps_1 must have just one input
[ ERROR ] Traceback -(most recent call last):
File "/opt/intel/openvino_2020.2.120/deployment_tools/model_optimizer/mo/utils/class_registration.py", line 288, in apply_transform
for_graph_and_each_sub_graph_recursively(graph, replacer.find_and_replace_pattern)
File "/opt/intel/openvino_2020.2.120/deployment_tools/model_optimizer/mo/middle/pattern_match.py", line 58, in for_graph_and_each_sub_graph_recursively
func(graph)
File "/opt/intel/openvino_2020.2.120/deployment_tools/model_optimizer/mo/front/common/replacement.py", line 150, in find_and_replace_pattern
apply_pattern(graph, action=self.replace_sub_graph, **self.pattern())
File "/opt/intel/openvino_2020.2.120/deployment_tools/model_optimizer/mo/middle/pattern_match.py", line 95, in apply_pattern
action(graph, match)
File "/opt/intel/openvino_2020.2.120/deployment_tools/model_optimizer/extensions/front/no_op_eraser.py", line 40, in replace_sub_graph
graph.erase_node(match['noop'])
File "/opt/intel/openvino_2020.2.120/deployment_tools/model_optimizer/mo/graph/graph.py", line 626, in erase_node
assert len(inputs) <= 1, "The node {} must have just one input".format(node.soft_get('name'))
AssertionError: The node group_deps_1 must have just one input
The above exception was the direct cause of the following exception:
File "/opt/intel/openvino_2020.2.120/deployment_tools/model_optimizer/mo/main.py", line 307, in main
return driver(argv)
File "/opt/intel/openvino_2020.2.120/deployment_tools/model_optimizer/mo/main.py", line 272, in driver
ret_res = emit_ir(prepare_ir(argv), argv)
File "/opt/intel/openvino_2020.2.120/deployment_tools/model_optimizer/mo/main.py", line 237, in prepare_ir
graph = unified_pipeline(argv)
File "/opt/intel/openvino_2020.2.120/deployment_tools/model_optimizer/mo/pipeline/unified.py", line 29, in unified_pipeline
class_registration.ClassType.BACK_REPLACER
File "/opt/intel/openvino_2020.2.120/deployment_tools/model_optimizer/mo/utils/class_registration.py", line 334, in apply_replacements
apply_replacements_list(graph, replacers_order)
File "/opt/intel/openvino_2020.2.120/deployment_tools/model_optimizer/mo/utils/class_registration.py", line 324, in apply_replacements_list
num_transforms=len(replacers_order))
File "/opt/intel/openvino_2020.2.120/deployment_tools/model_optimizer/mo/utils/logger.py", line 124, in wrapper
function(*args, **kwargs)
File "/opt/intel/openvino_2020.2.120/deployment_tools/model_optimizer/mo/utils/class_registration.py", line 312, in apply_transform
)) from err
Exception: Exception occurred during running replacer "None (<class 'extensions.front.no_op_eraser.NoOpEraser'>)": The node group_deps_1 must have just one input
[ ERROR ] ---------------- END OF BUG REPORT --------------
Also tried with the following command
(base) dhanu@myVM:~$ python3 /opt/intel/openvino_2020.2.120/deployment_tools/model_optimizer/mo_tf.py --input_model /home/dhanu/Downloads/model4_256/output/graph.pbtxt --input_checkpoint /home/dhanu/Downloads/model4_256/output/model.ckpt-3000.data-00000-of-00001 --input_model_is_text
Common parameters:
- Log level: ERROR
- Input layers: Not specified, inherited from the model
[ FRAMEWORK ERROR ] Cannot load input model: Op type not registered 'MapAndBatchDataset' in binary running on myVM. Make sure the Op and Kernel are registered in the binary running in this process. Note that if you are loading a saved graph which used ops from tf.contrib, accessing (e.g.) `tf.contrib.resampler` should be done before importing the graph, as contrib ops are lazily registered when the module is first accessed.
Note: The model is fine tuned using BERT uncased_L-12_H-768_A-12 with tensorflow 1.14
Tensorflow version - 1.14
Openvino version - openvino_2020.2.120
OS - Ubuntu
CPU specs:
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
CPU(s): 2
On-line CPU(s) list: 0,1
Thread(s) per core: 2
Core(s) per socket: 1
Socket(s): 1
NUMA node(s): 1
Vendor ID: GenuineIntel
CPU family: 6
Model: 85
Model name: Intel(R) Xeon(R) Platinum 8171M CPU @ 2.60GHz
Stepping: 4
CPU MHz: 2095.193
BogoMIPS: 4190.38
Virtualization: VT-x
Hypervisor vendor: Microsoft
Virtualization type: full
L1d cache: 32K
L1i cache: 32K
L2 cache: 1024K
L3 cache: 36608K
NUMA node0 CPU(s): 0,1
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ss ht syscall nx pdpe1gb rdtscp lm constant_tsc rep_good nopl xtopology cpuid pni pclmulqdq vmx ssse3 fma cx16 pcid sse4_1 sse4_2 movbe popcnt aes xsave avx f16c rdrand hypervisor lahf_lm abm 3dnowprefetch invpcid_single pti tpr_shadow vnmi ept vpid fsgsbase bmi1 hle avx2 smep bmi2 erms invpcid rtm mpx avx512f avx512dq rdseed adx smap clflushopt avx512cd avx512bw avx512vl xsaveopt xsavec xsaves
Hi Dhanunjay,
I’ve replicated your issue using a supported pre-trained BERT model.
I would suggest you use ‘inference_graph.pb’ input model instead.
Detailed information is available in the section “Convert Reshape-able TensorFlow BERT Model to the Intermediate Representation”, at the following page:
Munesh
