I am debugging my network so I have a chance to look at the source code of NCS installed at /usr/local/bin/ncssdk
. I do not quite understand the logic of parse_tensor
in which it iterates on each ops and attach to the network
object. However at some layers there are local attachments, for example Conv2D
attached with SeparableConv2dNative
, and then Conv2D
is attached again to the network which may create cyclic paths I guess?
@dpvo You can try using mvNCProfile to check if this is indeed the case with your model. mvNCProfile creates a visual representation of the model from input to output by creating a output_report.html file and a output.gv.svg image of the network layers.
Topic Options
