6592 Discussions
MYRIAD_ERROR - Running custom TensorFlow model on NCS
Hi all,
I've implemented a custom network (LeNet-5) in TensorFlow, trained it and then saved the graph (https://github.com/vincenzosantopietro/LeNet-5-Tensorflow).
After that, I've created a new version of the network for inference purposes and re-saved the graph.
import tensorflow as tf from tensorflow.contrib.layers import flatten import sys num_outputs = 10 def lenet(x): # Layer 1: Input 32x32x1, Output 28x28x6 conv1_kernels = tf.Variable(tf.truncated_normal(shape=[5, 5, 1, 6], mean=0, stddev=1)) conv1_biases = tf.get_variable(name="conv1_biases", shape=[6], initializer=tf.random_normal_initializer(stddev=0.3)) with tf.name_scope("ConvPoolReLU1"): conv1 = tf.nn.conv2d(x,conv1_kernels, [1, 1, 1, 1], padding='VALID') + conv1_biases # Pooling -> from 28x28 to 14x14 pool1 = tf.nn.max_pool(conv1, ksize=[1, 2, 2, 1], strides=[1, 2, 2, 1], padding='VALID') # Activation conv1 = tf.nn.relu(pool1) # Layer 2: Input 14x14x6, Output 10x10x16 conv2_kernels = tf.Variable(tf.truncated_normal(shape=[5, 5, 6, 16], mean=0, stddev=1)) conv2_biases = tf.get_variable(name="conv2_biases", shape=[16], initializer=tf.random_normal_initializer(stddev=1)) with tf.name_scope("ConvPoolReLU2"): conv2 = tf.nn.conv2d(conv1, conv2_kernels, [1, 1, 1, 1], padding='VALID') + conv2_biases # Pooling -> from 10x10x16 to 5x5x16 pool2 = tf.nn.max_pool(conv2, ksize=[1, 2, 2, 1], strides=[1, 2, 2, 1], padding='VALID') # Activation 2 conv2 = tf.nn.relu(pool2) # Flatten -> from 5x5x16 to 400x1 flattened = flatten(conv2) with tf.name_scope("FullyConnectedLayer1"): # Fully Connected Layer n.1 fcl1_weights = tf.Variable(tf.truncated_normal(shape=[400, 120], mean=0, stddev=1)) fcl1_biases = tf.get_variable(name="fc1_biases", shape=[120], initializer=tf.random_normal_initializer(stddev=1)) fcl1 = tf.matmul(flattened, fcl1_weights) + fcl1_biases # Activation 3 fcl1 = tf.nn.relu(fcl1) with tf.name_scope("FullyConnectedLayer2"): # Fully Connected Layer n.2 fcl2_weights = tf.Variable(tf.truncated_normal(shape=[120, 84], mean=0, stddev=1)) fcl2_biases = tf.get_variable(name="fc2_biases", shape=[84], initializer=tf.random_normal_initializer(stddev=1)) fcl2 = tf.matmul(fcl1, fcl2_weights) + fcl2_biases # Activation 4 fcl2 = tf.nn.relu(fcl2) with tf.name_scope("FullyConnectedLayer3"): # Fully Connected Layer n.3 fcl3_weights = tf.Variable(tf.truncated_normal(shape=[84, 10], mean=0, stddev=1)) fcl3_biases = tf.get_variable(name="fc3_biases", shape=[10], initializer=tf.random_normal_initializer(stddev=1)) logits = tf.matmul(fcl2, fcl3_weights) + fcl3_biases return logits def main(_): print('Saving model for inference on Intel\'s Neural Compute Stick') # Create the model x = tf.placeholder(tf.float32, [1,32, 32, 1], name='input') logits = lenet(x) output = tf.nn.softmax(logits,name='softmax') saver = tf.train.Saver(tf.global_variables()) with tf.Session() as sess: sess.run(tf.global_variables_initializer()) sess.run(tf.local_variables_initializer()) saver.restore(sess, 'tmp/model.ckpt') saver.save(sess, 'tmp/model-inference') if __name__ == '__main__': tf.app.run(main=main, argv=[sys.argv[0]])
Then I used the mvNCCompile command to export the .graph file needed by the NCS: ``mvNCCompile model-inference.meta -s 12 -in=input -on=softmax -is 32 32 -o lenet5.graph
I've also implemented a new script to load the model on the NCS and make some inference on the MNIST dataset (there's padding around images to make the input size fit) but when I run it, the NCS keeps reporting MYRIAD_ERROR.
from mvnc import mvncapi as mvnc import sys import numpy as np import cv2 from tensorflow.examples.tutorials.mnist import input_data import tensorflow as tf mnist = input_data.read_data_sets("MNIST_data/", reshape=False, one_hot=True) X_test, y_test = mnist.test.images, mnist.test.labels X_test = np.pad(X_test, ((0, 0), (2, 2), (2, 2), (0, 0)), 'constant') # Enumerating devices mvnc.SetGlobalOption(mvnc.GlobalOption.LOG_LEVEL, 2) devices = mvnc.EnumerateDevices() if len(devices) == 0: print('No devices found') quit() #Opening NCS device device = mvnc.Device(devices[0]) device.OpenDevice() with open('lenet5.graph',mode='rb') as f: graphfile = f.read() print('lenet-5 for MNIST_data - Input Size: 32x32x1') graph = device.AllocateGraph(graphfile) for i in range(len(X_test)/10): cv2.imshow("img",X_test[i]) if cv2.waitKey(200) > 0: graph.DeallocateGraph() device.CloseDevice() exit() x = np.reshape(X_test[i].astype(np.float32),(1,32,32,1)) if(graph.LoadTensor(x,None)): print('Loaded Tensor') output, _ = graph.GetResult() #print('output:' + output) graph.DeallocateGraph() device.CloseDevice() print('Finished')
Extracting MNIST_data/train-images-idx3-ubyte.gz
Extracting MNIST_data/train-labels-idx1-ubyte.gz
Extracting MNIST_data/t10k-images-idx3-ubyte.gz
Extracting MNIST_data/t10k-labels-idx1-ubyte.gz
Device 0 Address: 7 - VID/PID 03e7:2150
Starting wait for connect with 2000ms timeout
Found Address: 7 - VID/PID 03e7:2150
Found EP 0x81 : max packet size is 512 bytes
Found EP 0x01 : max packet size is 512 bytes
Found and opened device
Performing bulk write of 865724 bytes…
Successfully sent 865724 bytes of data in 227.821180 ms (3.623977 MB/s)
Boot successful, device address 7
Device 0 Address: 1 - VID/PID 03e7:f63b
Found Address: 1 - VID/PID 03e7:f63b
done
Booted 1 -> VSC
Loaded Tensor
Traceback (most recent call last):
File "inference_script.py", line 43, in
File "/usr/local/lib/python2.7/dist-packages/mvnc/mvncapi.py", line 264, in GetResult
raise Exception(Status(status))
Exception: mvncStatus.MYRIAD_ERROR
I'm using the NCS on my MacBook Pro on Ubuntu 16.04.
Is this error related to the inference model or the script I made to load the model on the NCS?
@vincenzosantopietro Can you provide a link to your meta files? I'd like to try to help you debug this issue by reproducing the issue myself on my bench. Thanks.
Hi @Tome_at_Intel , thanks for your comment.
You can download meta files here.
@vincenzosantopietro Hi Vincent. I was not able to reproduce your issue "myriad error", but I did run into a different error "[Error 25] Myriad Error: "5x5 Convolution outputChannels Dimension too small."". I was using your myriad-inference.meta model files. By default, the SDK chooses an optimized function that requires the channels to be >= 8.
I found a workaround with this issue by including a conf file named "model-inference.conf" with the following content: (Make sure there is an extra line after the last line in the conf file or else it will not parse correctly.)
ConvPoolReLU1/Conv2D generic_spatial ConvPoolReLU2/Conv2D generic_spatial
