I installed DL workbench on wind10 by using docker hub, the problem is that MYRIAD(neural compute stick ) is not detected by dl workbench, i have only cpu. and after that I installed it on linux (substym on wind10 ) and it was the same probem. so what i have to do please
Hi Amcharlal,
Myriad plugin is not supported for DL Workbench on Windows 10. The information is provided in the link below:
https://docs.openvinotoolkit.org/2021.2/workbench_docs_Workbench_DG_Install_Workbench.html##minimum
For Linux version, only Ubuntu 18.04 LTS version is supported and have been validated.
You can get the related information here:
Windows Subsystem for Linux (WSL) meanwhile is just a terminal environment and doesn’t seem to include processing around USB. I would suggest you use DL Workbench in Ubuntu 18.04 LTS environment if you want to use MYRIAD plugin.
Munesh
Hi Amcharlal,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Munesh
