Hi guys, I am facing issues trying to implement the live object detector sample provided with ncappzoo v1 in C++ for NCSDK v2. Could you please look into my code or share with me a working code? I have tried row major, col major, changing tensor datatype, rgb and bgr conversion and everything I could think of. I am new to this and would be grateful if you could help me out. It always returns one/two detections for tv monitor and train and nothing else.
//the problem is somewhere here
bool preprocess_image(const cv::Mat& src_image_mat, cv::Mat& preprocessed_image_mat)
// find ratio of to adjust width and height by to make them fit in network image width and height
double width_ratio = (double)NETWORK_IMAGE_WIDTH / (double)src_image_mat.cols;
double height_ratio = (double)NETWORK_IMAGE_HEIGHT / (double)src_image_mat.rows;
// the largest ratio is the one to use for scaling both height and width.
double largest_ratio = (width_ratio > height_ratio) ? width_ratio : height_ratio;
cv::resize(src_image_mat, preprocessed_image_mat, cv::Size(), largest_ratio, largest_ratio, CV_INTER_AREA);
int mid_row = preprocessed_image_mat.rows / 2.0;
int mid_col = preprocessed_image_mat.cols / 2.0;
int x_start = mid_col - (NETWORK_IMAGE_WIDTH / 2);
int y_start = mid_row - (NETWORK_IMAGE_HEIGHT / 2);
cv::Rect roi(x_start, y_start, NETWORK_IMAGE_WIDTH, NETWORK_IMAGE_HEIGHT);
preprocessed_image_mat = preprocessed_image_mat(roi);
//RGB to BRG
//cvtColor(preprocessed_image_mat, preprocessed_image_mat, COLOR_RGB2BGR);
return true;
std::shared_ptr<list<networkResults>> getInferenceResults(cv::Mat inputMat,
struct ncGraphHandle_t* graphHandle, struct ncFifoHandle_t* fifoIn,
struct ncFifoHandle_t* fifoOut)
cv::Mat preprocessed_image_mat;
preprocess_image(inputMat, preprocessed_image_mat);
if (preprocessed_image_mat.rows != NETWORK_IMAGE_HEIGHT ||
preprocessed_image_mat.cols != NETWORK_IMAGE_WIDTH) {
cout << "Error - preprocessed image is unexpected size!" << endl;
return 0;
float_t tensor32[NETWORK_IMAGE_WIDTH * NETWORK_IMAGE_HEIGHT * 3];
uint8_t* image_data_ptr = (uint8_t*)preprocessed_image_mat.data;
int chan = preprocessed_image_mat.channels();
int tensor_index = 0;
for (int col = 0; col < preprocessed_image_mat.cols; col++) {
for (int row = 0; row < preprocessed_image_mat.rows; row++) {
int pixel_start_index = col * (preprocessed_image_mat.rows + 0) * chan + row * chan; // TODO: don't hard code
// assuming the image is in BGR format here
uint8_t blue = image_data_ptr[pixel_start_index + 0];
uint8_t green = image_data_ptr[pixel_start_index + 1];
uint8_t red = image_data_ptr[pixel_start_index + 2];
tensor32[tensor_index++] = (((float_t)blue - networkMean) * networkStd);
tensor32[tensor_index++] = (((float_t)green - networkMean) * networkStd);
tensor32[tensor_index++] = (((float_t)red - networkMean) * networkStd);
// queue for inference
unsigned int inputTensorLength = NETWORK_IMAGE_HEIGHT * NETWORK_IMAGE_WIDTH * 3 * sizeof(float_t);
retCode = ncGraphQueueInferenceWithFifoElem(graphHandle, fifoIn, fifoOut, tensor32, &inputTensorLength, 0);
if (retCode != NC_OK) {
cout << "Error[" << retCode << "] - could not queue inference." << endl;
return 0;
// get the size of the result
unsigned int res_length;
unsigned int option_length = sizeof(res_length);
retCode = ncFifoGetOption(fifoOut, NC_RO_FIFO_ELEMENT_DATA_SIZE, &res_length, &option_length);
cout << "Error[" << retCode << "] - could not get output result size." << endl;
return 0;
float_t result_buf[res_length];
retCode = ncFifoReadElem(fifoOut, result_buf, &res_length, NULL);
cout << "Error[" << retCode << "] - could not get output result." << endl;
return 0;
list<networkResult> *objectInferenceResults = new list<networkResult>();
float number = *result_buf;
for (int n = 0; n < number; ++n)
float* pointer = result_buf + (7 + n * 7);
if (pointer[2] > CONFIDENCE_THRESHOLD)
networkResult r;
r.class_ID = pointer[1];
r.confidence = pointer[2] * 100;
r.x1 = pointer[3] * NETWORK_IMAGE_WIDTH;
r.y1 = pointer[4] * NETWORK_IMAGE_HEIGHT;
r.x2 = pointer[5] * NETWORK_IMAGE_WIDTH;
r.y2 = pointer[6] * NETWORK_IMAGE_HEIGHT;
objectInferenceResults->push_back(r);
return std::shared_ptr<list<networkResult>>(objectInferenceResults);
int main(int argc, char** argv) {
// Camera and image frames
VideoCapture capture;
Mat imgIn;
// Key to escape from main loop and close program
const int breakKey = 27; // esc == 27
int key;
// Struct that will hold inference results
std::shared_ptr<list<networkResult>>(Result);
// Set up the camera
capture.open(CAM_SOURCE);
capture.set(CV_CAP_PROP_FRAME_WIDTH, WINDOW_WIDTH);
capture.set(CV_CAP_PROP_FRAME_HEIGHT, WINDOW_HEIGHT);
// Set up the display window
namedWindow(WINDOW_NAME, WINDOW_NORMAL);
resizeWindow(WINDOW_NAME, WINDOW_WIDTH, WINDOW_HEIGHT);
setWindowProperty(WINDOW_NAME, CV_WND_PROP_ASPECTRATIO, CV_WINDOW_KEEPRATIO);
moveWindow(WINDOW_NAME, 0, 0);
Point winTextOrigin(0, 20);
// Initialize the NCS device(s) and network graphs and FIFO queues
initNCS();
unsigned int frame_count = 0;
//Initialize Mobilenet SSD graph with IO FIFOs
initSSD();
// main loop
while (true) {
// If the user presses the break key exit the loop
key = waitKey(1);
if ((key & 0xFF) == breakKey) {
break;
// Get a frame from the camera
capture >> imgIn;
if (frame_count++ >= SKIP_AFTER)
capture >> imgIn;
frame_count = 0;
// Flip the image horizontally
//flip(imgIn, imgIn, 1);
//Inference
Result = getInferenceResults(imgIn, ssd_graph_handle, ssd_fifo_in, ssd_fifo_out);
// Draw labels and rectangles on the image
putText(imgIn, "Press ESC to exit", winTextOrigin, FONT, 2, GREEN, 2);
for (list<networkResult>::iterator it = Result->begin(); it != Result->end(); it++) {
// Draw a rectangle around the detected face
rectangle(imgIn, Point(it->x1, it->y1), Point(it->x2, it->y2), RED, 1, 8, 0);
// print the age and gender text to the window
putText(imgIn, LABELS[it->class_ID], Point(it->x2, it->y2), FONT, FONT_SIZE, BLACK, 3);
// Show the image in the window
imshow(WINDOW_NAME, imgIn);
} // end main while loop
//Close device and deallocate graph
closeNCS();
return 0;
Topic Options
