6597 Discussions
Model Optimizer incorrect output shape using --input
TCame
I'm trying to optimize the deeplab model for a NCS2 using the following command:
$python /opt/intel/openvino/deployment_tools/model_optimizer/mo_tf.py --input_model frozen_inference_graph.pb --data_type FP16 --input "ImageTensor[1 224 224 3]" --output SemanticPredictions --output_dir ./irGraph/
But the problem I'm running into is that the first input for the output .xml file looks like:
<?xml version="1.0" ?> <net batch="1" name="frozen_inference_graph" version="6"> <layers> <layer id="0" name="sub_2/negate_/Output_0/Data__const" precision="FP16" type="Const"> <output> <port id="1"> <dim>1</dim> <dim>1</dim> <dim>3</dim> </port> </output> <blobs> <custom offset="0" size="12"/> </blobs> </layer> <layer id="1" name="ImageTensor" precision="FP16" type="Input"> <output> <port id="0"> <dim>1</dim> <dim>3</dim> <dim>224</dim> <dim>224</dim> </port> </output> </layer>
The problem being the shape of the first layer, which doesn't have the correct shape and as a result is unable to be processed by the inference engine.
What I'm trying to do is to use the model optimizer to cut that first layer off by specifiying the input tensor with --input. Any help would be appreciated.
Here is a link to the model:
http://download.tensorflow.org/models/deeplabv3_mnv2_pascal_train_aug_2018_01_29.tar.gz
Tim
David_C_Intel
Hi TCame,
Thank you for contacting Intel Customer Support, I am glad to assist you.
I am looking into your request, and will get back to you as soon as possible.
David C.
A Contingent Worker at Intel
David_C_Intel
Hi TCame,
Thank you for your patience.
In order to convert the deeplab model to IR, you need to run the following command:
python3 ~/intel/openvino/deployment_tools/model_optimizer/mo.py --input_model frozen_inference_graph.pb --input 1:mul_1 --output ArgMax --reverse_input_channels --input_shape [1,513,513,3] --data_type FP16
After converting your files, could you please test them with the segmentation demo and let me know if you still get errors?
David C.
TCame
Hi David,
Yes that worked perfectly, thanks for your help.
Tim
David_C_Intel
Hi TCame,
Thank you for contacting us, I am happy to help you fix your issue.
I am going to close this thread, if you need further assistance, do not hesitate to contact us again.
Have a nice day!
David C.
