6594 Discussions
ModuleNotFoundError: No module named 'openvino' in Docker
andife
I want to use docker for non-interactive analysis of openvino use cases (speed, preprocessing, different input formats...)
Therefore I created a dockerfile with the following content (I know I tried different variants..)
FROM openvino/ubuntu18_dev:latest
ENV PYTHON_PATH /opt/intel/openvino/python/python3.6:/opt/intel/openvino/python/python3:/opt/intel/openvino/deployment_tools/tools/post_training_optimization_toolkit:/opt/intel/openvino/deployment_tools/open_model_zoo/tools/accuracy_checker:/opt/intel/openvino/deployment_tools/model_optimizer
RUN apt-get update; apt-get install -f -y ca-certificates
RUN apt install -f -y vim ffmpeg libsm6 libxext6 libgl1-mesa-dev
RUN update-ca-certificates
RUN apt-get update
USER openvino
RUN source /opt/intel/openvino/bin/setupvars.sh
RUN mkdir ~/env
RUN python3 -m venv ~/env/tensorflow2 --system-site-packages
RUN source ~/env/tensorflow2/bin/activate
RUN pip3 install opencv-python --trusted-host="pypi.org"
RUN /bin/bash -c "source /opt/intel/openvino/bin/setupvars.sh"
RUN echo "source /opt/intel/openvino/bin/setupvars.sh" >> /home/openvino/.bashrc
RUN python3 ~/run_inference_latest.py
I used the commands
docker build -t ml .
docker run --rm -v /mnt/tf2foropenvino/:/data ml
and got
+ python3 /home/openvino/run_inference_latest.py
Traceback (most recent call last):
File "/home/openvino/run_inference_latest.py", line 4, in <module>
import openvino
Accessing the container and executing the command manually works
docker run -it -v /mnt/tf2foropenvino/:/data ml bash
Zulkifli_Intel
Hello andife,
Greetings to you
When running the docker build . -t <image-name> (i.e. docker build . -t openvino-ubuntu) to build Docker image, then you need to run the image interactively with docker run -it <image_name> (i.e. docker run -it openvino-ubuntu).
To verify Python is able to import IECore from openvino module, test it with Python interpreter:
python3
>>> from openvino.inference_engine import IECore
Please share with us more detail on what you trying to achieve.
Sincerely,
Zulkifli
Zulkifli_Intel
Hello andife,
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Sincerely,
Zulkifli
