6555 Discussions
No Grayscale in ov::preprocess::ColorFormat?
jrrw1
Hello, I am currently trying to deploy a cv model in C++ using Openvino API.
My model only takes in grayscale images. When I set up my PrePostProcessor input preprocess, there is no grayscale in ov::preprocess::ColorFormat. This is confirmed in ColorFormat documentation.
The code below is the correct way to do this with an RBG image, however I am unsure how to achieve this with grayscale, as GRAY is not supported in ov::preprocess::ColorFormat.  Any help is greatly appreciated!
// Inizialize Preprocessing for the model
ov::preprocess::PrePostProcessor ppp = ov::preprocess::PrePostProcessor(model);
// Specify input image format
ppp.input().tensor().set_element_type(ov::element::u8).set_layout("NHWC").set_color_format(ov::preprocess::ColorFormat::BGR);
// Specify preprocess pipeline to input image without resizing
  ppp.input().preprocess().convert_element_type(ov::element::f32).convert_color(ov::preprocess::ColorFormat::RGB).scale({255., 255., 255.});
Wan_Intel
Hi Jrrw1,
Input color format for preprocessing in OpenVINO™ Inference Engine C++ API are as follows:
  •   RAW
  •   RGB
  •   BGR
  •   RGBX
  •   BGRX
  •   NV12
  •   I420
For more information, please refer to the enum InferenceEngine::ColorFormat.
Wan
Wan_Intel
Hi Jrrw1,
Thanks for your question.
Please submit a new question if additional information is needed as this thread will no longer be monitored.
Wan
