6551 Discussions
Not getting correct predictions using OpenVino C++ while Python version is OK
TarunM
I need to convert my code to C++ for deployment purposes. My model, once converted to OpenVino, produces the expected results in Python but not in C++. I believe there might be an issue with my C++ implementation, possibly related to converting cv::Mat to an OpenVino tensor, perhaps involving the channel nhwc.
I've included a zipped file (files.zip) that contains:
  1. My Python code (providing the expected results)
  2. My C++ code (yielding different results)
  3. A test image used by both the C++ and Python files
  4. OpenVino converted model.
I've also written a function to analyze the differences in predictions between the C++ and Python implementations. The C++ code predicts and saves the result in a binary file, and the Python code predicts, reads the bin file, and calculates the error.
Please help.
(Virus scan in progress ...)
Hairul_Intel
Hi TarunM,
We're investigating this issue and will update you on any findings as soon as possible.
On a side note, could you share the following details with us:
  • OpenVINO version
  • OS version
Hairul
TarunM
OpenVino version 2023.0.1
OS: Windows 10
The model has been converted using the 2022 Openvino version.
TarunM
Is there any possibility that you will help in it ? or should I declare OpenVino is only good for toy AI applications and move on to other platforms for serious deployments?
TarunM
@Hairul is there any update?
Hairul_Intel
Hi TarunM,
We just got feedback from the Engineering team regarding this issue.
They confirmed that the problem was due to incorrect filling of tensor data in the preprocessing part of your C++ code. The channels in the attached model are on the last place, so they corrected the main.cpp (see the attachments).
Please test out using the new main.cpp file and let us know if the issue is resolved.
Hairul
Hairul_Intel
Hi TarunM,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Hairul
