I'm trying to run a video on a kv260.
I follow this tutorial (https://xilinx.github.io/kria-apps-docs/creating_applications/2022.1/build/html/docs/kria_vitis_acceleration_flow/petalinux-firmware.html) and I flash this petalinux (2022.1) with the configuration of the tutorial on the sd-card.
I saw that ffmpeg was not enabled so I follow the command below in this link (https://docs.amd.com/r/2022.1-English/ug1144-petalinux-tools-reference-guide/Adding-an-Existing-Recipe-into-the-Root-File-System) because I'm working with video -file.
After
-) petalinux -config -c rootfs where I enabled it
-) petalinux-build --sdk
-) ./sdk.sh
-) petalinux-package --wic --bootfiles "ramdisk.cpio.gz.u-boot boot.scr Image system.dtb"
Actually I run a c++ code created with Vitis 2022.2 where I print the build information with the function getBuildInformation() but I continue seeing this
Video I/O:
GStreamer: YES (1.18.5)
v4l/v4l2: YES (linux/videodev2.h)
gPhoto2: YES
without ffmpeg.
I also see this two warnings related to gstreamer that I don't understand how resolve.
[ WARN:0] global /usr/src/debug/opencv/4.5.2-r0/git/modules/videoio/src/cap_gstreamer.cpp (854) open OpenCV | GStreamer warning: Error opening bin: unexpected reference "video" - ignoring
[ WARN:0] global /usr/src/debug/opencv/4.5.2-r0/git/modules/videoio/src/cap_gstreamer.cpp (597) isPipelinePlaying OpenCV | GStreamer warning: GStreamer: pipeline have not been created
Unable to open file!
Could someone tell me what I'm doing wrong please?
Thanks in advance !
Hi Bugtechnz,
Your GStreamer issue is because the data stream is not present in a GSTPipeline. To use GStreamer, OpenCV expects a valid pipeline. You may check the Gstreamer capabilities.
However, for better support regarding OpenCV. I suggest you post your question on OpenCV Github. There is a similar issue in the forum that might help you.
https://github.com/opencv/opencv/issues/23864
Therefore, since this is not related to OpenVINO. I will proceed to close the case. This thread will no longer be monitored since we have provided information. If you need any additional information from Intel, please submit a new question.
Aznie
