6598 Discussions
NotFoundError [[Node: save/MergeV2Checkpoints...
SDK version: 2.05.00.02
USE_VIRTUALENV = yes
Python Version = 3.5.2
Tensorflow Version = 1.7.0
Here is an example training code that I'm running:
classifier = tf.estimator.DNNClassifier(feature_columns=feature_columns, hidden_units=[1802, 901, 450, 225], n_classes=2, model_dir="/tmp/")
When I try to compile the meta file:
mvNCCompile /tmp/test_model_7-26_v1/model.ckpt-100.meta -in enqueue_input/Placeholder -on save/Identity
I get the error:
NotFoundError (see above for traceback): ; No such file or directory [[Node: save/MergeV2Checkpoints = MergeV2Checkpoints[delete_old_dirs=true, _device="/job:localhost/replica:0/task:0/device:CPU:0"](save/MergeV2Checkpoints/checkpoint_prefixes, save/Const)]]
The first exception was:
/usr/lib/python3.5/site-packages/tensorflow/python/util/tf_inspect.py:45: DeprecationWarning: inspect.getargspec() is deprecated, use inspect.signature() instead shape: [1, 224, 224, 3] Traceback (most recent call last): File "/usr/lib/python3.5/site-packages/tensorflow/python/client/session.py", line 1327, in _do_call return fn(*args) File "/usr/lib/python3.5/site-packages/tensorflow/python/client/session.py", line 1312, in _run_fn options, feed_dict, fetch_list, target_list, run_metadata) File "/usr/lib/python3.5/site-packages/tensorflow/python/client/session.py", line 1420, in _call_tf_sessionrun status, run_metadata) File "/usr/lib/python3.5/site-packages/tensorflow/python/framework/errors_impl.py", line 516, in __exit__ c_api.TF_GetCode(self.status.status)) tensorflow.python.framework.errors_impl.NotFoundError: ; No such file or directory [[Node: save/MergeV2Checkpoints = MergeV2Checkpoints[delete_old_dirs=true, _device="/job:localhost/replica:0/task:0/device:CPU:0"](save/MergeV2Checkpoints/checkpoint_prefixes, save/Const)]]
Thank you for the support.
Michael
