OpenVINO 2019.1.114 on Ubuntu 18.04
McDonald__John
Is OpenVino 2019.1.114 compatible with Ubuntu 18.04?
I have just installed OpenVino 2019.1.114 on Ubuntu 18.04 but am having problems running some of the sample applications. The two demos (i.e.demo_security_barrier_camera.sh  and demo_squeezenet_download_convert_run.sh) run ok, but when I try to run anything else I keep getting the following error:
[ ERROR ] Cannot make shared blob! The blob type cannot be used to store objects of current precision
This is from models downloaded using the downloader.py. For example I have tried running the pedestrian tracker demo using the person detection and retail models as explained here: https://docs.openvinotoolkit.org/latest/_inference_engine_samples_pedestrian_tracker_demo_README.html
with the following output:
$ ./pedestrian_tracker_demo -i ~/Downloads/P1033658.mp4 -m_det /opt/intel/openvino_2019.1.144/deployment_tools/tools/model_downloader/Retail/object_detection/pedestrian/rmnet_ssd/0013/dldt/person-detection-retail-0013.xml -d_det CPU  -m_reid /opt/intel/openvino_2019.1.144/deployment_tools/tools/model_downloader/Retail/object_reidentification/pedestrian/rmnet_based/0031/dldt/person-reidentification-retail-0031.xml -d_reid CPU
InferenceEngine:
    API version ............ 1.6
    Build .................. custom_releases/2019/R1.1_28dfbfdd28954c4dfd2f94403dd8dfc1f411038b
[ INFO ] Parsing input parameters
Loading plugin CPU
    Build .................. 23780
    Description ....... MKLDNNPlugin
Has anyone experienced similar problems ... and more importantly got any suggested solutions?
John McDonald.
Shubha_R_Intel
Dear McDonald, John,
Ubuntu 18 is technically not supported by OpenVino. However, many in the community have made it work.
Shubha
