OpenVINO 2020 and iEi Mustang-V100-MX8
Quantitative_Finance
I have installed OpenVINO 2020 on Ubuntu 18.0.4 with an iEi Mustang-V100-MX8, but I am having trouble running the demo. I followed all the instructions, but I am getting several errors.  The hddldaemon fails with an error:
quantgeek@Ravana:/opt/intel/openvino/inference_engine/external/hddl/bin$ ./hddldaemon
./hddldaemon: symbol lookup error: /opt/intel/openvino_2020.1.023/deployment_tools/inference_engine/external/hddl/lib/libmvnc-hddl.so.0: undefined symbol: hddl_check_device
Running the demo produces the following error:
Run ./classification_sample_async -d HDDL -i /opt/intel/openvino/deployment_tools/demo/car.png -m /home/quantgeek/openvino_models/ir/public/squeezenet1.1/FP16/squeezenet1.1.xml
[ INFO ] InferenceEngine:
API version ............ 2.1
Build .................. 37988
Description ....... API
[ INFO ] Parsing input parameters
[ INFO ] Files were added: 1
[ INFO ]     /opt/intel/openvino/deployment_tools/demo/car.png
[ INFO ] Creating Inference Engine
[ ERROR ] Failed to create plugin /opt/intel/openvino_2020.1.023/deployment_tools/inference_engine/lib/intel64/libHDDLPlugin.so for device HDDL
Please, check your environment
Cannot load library '/opt/intel/openvino_2020.1.023/deployment_tools/inference_engine/lib/intel64/libHDDLPlugin.so': /opt/intel/openvino_2020.1.023/deployment_tools/inference_engine/external/hddl/lib/libmvnc-hddl.so.0: undefined symbol: hddl_check_device
Error on or near line 217; exiting with status 1
The drivers are all loaded and I can reset it without a problem using bsl_reset, so what gives?
QG
Max_L_Intel
Hello.
Please ensure you have carefully followed all the additional steps from the following link required for configuring IEI Mustang-V100-MX8 -
- https://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_linux_ivad_vpu.html
Especially setting the environment variables:
source /opt/intel/openvino/bin/setupvars.sh
If so, then please run this 'source' command once again right before running classification_sample_async. Let me know the result.
Best regards, Max.
Figured out what the problem is. Apparently, 2020 changed the way the hddldaemon is created.  A new function was added called hddl_check_device which is NOT present in any of the iEi drivers and software.  Hence the instructions are obsolete as the daemon can never run as the dynamic libraries from iEi can't be used in 2020.  Can you or some update the drivers and/or documentation? Hope you guys release the source code the HDDL drivers like you did the Movidus drivers...
Max_L_Intel
On my end I have run a fresh OpenVINO Toolkit 2020.1 build installation with Mustang-V100-MX8 installed on Ubuntu 18.04 OS. So as a results, I am able to successfully execute classification_sample_async application with HDDL plugin.
Please let me know if you have or had before any other OpenVINO builds installed on this machine? If so, in that case it's important to set the correct environment variables exactly for 2020.1 build.
Best regards, Max.
Bansal__Ishant
You must be using  linux 5.3 kernel , which is not supported as per release notes of 2020.1 ver . use lower ver kernel , it will work fine
Max_L_Intel
That's correct. Per the release notes for OpenVINO toolkit 2020.1 build, for HDDL plugin there are Linux kernel versions 5.2 and below are only supported.
kien_leong__tan
I also faced the same error but I installed OpenVINO 2020 on Ubuntu 16.04 with an iEi Mustang-V100-MX8
Below the output of uname -a
Linux ubuntu-OptiPlex-7050 4.15.0-88-generic #88~16.04.1-Ubuntu SMP Wed Feb 12 04:19:15 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
Does OpenVINO 2020 still support Ubuntu 16.04?
Marcia_W_Intel
quantitative-finance-geek wrote:
"... Can you or some update the drivers and/or documentation? Hope you guys release the source code the HDDL drivers like you did the Movidus drivers..."
Did you see:
                       /opt/intel/openvino/inference_engine/external/HDDL/drivers
Also, thanks for the information regarding the need for documentation! - FOSS content creator :)
Max_L_Intel
Hello, kien leong, tan
Per the release notes, OpenVINO toolkit build 2020.1 has not been officially validated for Ubuntu 16.04 - https://software.intel.com/en-us/articles/OpenVINO-RelNotes
However, the driver is still there, so there's a high chance that it works. Have you already tried all the recommendations from this topic?
If that still does not work, please also have a chance to try one of OpenVINO toolkit previous builds (2018) with official Ubuntu 16.04 support - https://software.intel.com/en-us/articles/OpenVINO-RelNotes-2018
kien_leong__tan
Hi Max L.
I tried with OpenVINO 2019.3.376 and it work.
Any chances OpenVINO 2020 will support Ubuntu 16.04 in the future?
Max_L_Intel
kien leong, tan wrote:
Hi Max L.
Hi, kien leong, tan.
Unfortunately, we can't comment on future releases and features, because they are subject to change. But if you would like to continue to use OpenVINO toolkit 2020.1 build, then we would recommend you to go further with Ubuntu 18.04 version.
AlexCKLam
I am running into similar error with OpenVINO 2021.1
[ ERROR ] Failed to create plugin /opt/intel/openvino_2021/deployment_tools/inference_engine/lib/intel64/libHDDLPlugin.so for device HDDL
Cannot load library '/opt/intel/openvino_2021/deployment_tools/inference_engine/lib/intel64/libHDDLPlugin.so': libboost_filesystem.so.1.65.1: cannot open shared object file: No such file or directory
ldconfig --version shows libboost_filesystem.so.1.65.1 is in /usr/lib/x86_64-linux-gnu
so I don't understand the issue.
