6605 Discussions
OpenVINO Inference Engine uses synchronous or asynchronous inference mode
nat98
Hello there,
I am doing some benchmark/comparison for my original (unoptimized) model and the OpenVINO (optimized) model. The performance evaluation of the optimized model is done using DL Workbench.
Now, I would like to know that, what is the default inference mode when I am measuring throughput/accuracy/latency in DL Workbench? Is it synchronous or asynchronous inference mode?
nat98
Wan_Intel
Hi Nat98,
For your information, the default inference mode when measuring throughput/accuracy/latency in DL Workbench is the asynchronous inference mode.
Wan
Wan_Intel
Hi Nat98,
Wan
artyom_tugaryov
Hello @nat98 ,
DL Workbench runs benchmark application with default inference mode to measure performance of a model. The default inference mode in benchmark application is the asynchronous mode.
To measure accuracy of a model DL Workbench uses  accuracy_checker with the asynchronous mode by default.
nat98
Hello Wan_Intel and artyom_tugaryov,
Thanks for answering my question and thanks for both of your replies.
Nathaniel Tan
Wan_Intel
Hi Nat98,
You are welcome.
This thread will no longer be monitored since this issue has been resolved.
If you need any additional information from Intel, please submit a new question.
Wan
