6605 Discussions
OpenVINO demo "demo_squeezenet_download_convert_run" not working.
Lablace
I recently installed Intel OpenVINO toolkit successfully. But when I tried to run one of the demos, the demo_squeezenet_download_convert_run.bat, it failed to work at the very last step.
###############|| Generate VS solution for Inference Engine samples using cmake ||###############
等待 3 秒,按一个键继续 ...
Creating Visual Studio 16 2019 x64 files in C:\Users\***\Documents\Intel\OpenVINO\inference_engine_samples_build...
-- Selecting Windows SDK version 10.0.18362.0 to target Windows 10.0.18363.
-- Configuring done
-- Generating done
-- Build files have been written to: D:/IntelOpenVINO/openvino/deployment_tools/inference_engine/samples/cpp
等待 7 秒,按一个键继续 ...
###############|| Build Inference Engine samples using MS Visual Studio (MSBuild.exe) ||###############
等待 2 秒,按一个键继续 ...
"C:\Visual Studio\MSBuild\Current\Bin\MSBuild.exe" Samples.sln /p:Configuration=Release /t:cpp_samples\classification_sample_async /clp:ErrorsOnly /m
用于 .NET Framework 的 Microsoft (R) 生成引擎版本 16.7.0+b89cb5fde
版权所有(C) Microsoft Corporation。保留所有权利。
等待 6 秒,按一个键继续 ...
###############|| Run Inference Engine classification sample ||###############
等待 2 秒,按一个键继续 ...
已复制 1 个文件。
classification_sample_async.exe -i "D:\IntelOpenVINO\openvino\deployment_tools\demo\car.png" -m "C:\Users\***\Documents\Intel\OpenVINO\openvino_models\ir\public\squeezenet1.1\FP16\squeezenet1.1.xml" -d CPU
###############|| Classification demo completed successfully ||###############
等待 8 秒,按一个键继续 ...
I have refered to this page, but I believe it would not be the network problem. I have tried to run the execute file but it seemed that it would never parse any argument, even the "-h" which should have it show the usage (this was shown in the following source code.)
static void showUsage() {
std::cout << std::endl;
std::cout << "classification_sample_async [OPTION]" << std::endl;
std::cout << "Options:" << std::endl;
std::cout << " -h " << help_message << std::endl;
std::cout << " -i \"<path>\" " << image_message << std::endl;
std::cout << " -m \"<path>\" " << model_message << std::endl;
std::cout << " -l \"<absolute_path>\" " << custom_cpu_library_message << std::endl;
std::cout << " Or" << std::endl;
std::cout << " -c \"<absolute_path>\" " << custom_cldnn_message << std::endl;
std::cout << " -d \"<device>\" " << target_device_message << std::endl;
std::cout << " -nt \"<integer>\" " << ntop_message << std::endl;
So I believe it wasn't compiled in the right way. Any help may be offered? Many thanks!
Lablace
Thank you, Iffa.
Sorry but this didn't help. As I followed the Installation Guide detailedly, I am sure that I had installed all the dependencies and pre-requisites. Eventually I have managed to work it out or so, but I have more to tell here.
First, it would be nice if you could change all the "cd" in the demo batch files to "cd /d." Adding a "/d" switch does help when people choose to install the ToolKit in anything other than the SystemDrive (where Users directories are.) If not, it would be a mess because command prompt can't change directories successfully.
Second, it seemed that the following command couldn't get the right version of MSBuild.exe.
if exist "C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\MSBuild\15.0\Bin\MSBuild.exe" (
set "MSBUILD_BIN=C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\MSBuild\15.0\Bin\MSBuild.exe"
set "MSBUILD_VERSION=15 2017"
) else (
if not "!MSBUILD_BIN:2019=!"=="!MSBUILD_BIN!" set "MSBUILD_VERSION=16 2019"
if not "!MSBUILD_BIN:2017=!"=="!MSBUILD_BIN!" set "MSBUILD_VERSION=15 2017"
if not "!MSBUILD_BIN:2015=!"=="!MSBUILD_BIN!" set "MSBUILD_VERSION=14 2015"
I didn't quite understand what the bolded command meant but when I deleted the not, as
if "!MSBUILD_BIN:2019=!"=="!MSBUILD_BIN!" set "MSBUILD_VERSION=16 2019"
It did set the right version.
Third, when I ran command prompt in Administrator mode, and ran the demo, it didn't prompt any error message, which got me puzzled, so I wrote the original post here. But when I ran both of them in Normal mode, it prompted an error message, the same as this post, and the method in that post helped! I compiled it in debug mode and it worked.
I still couldn't quite understand what happened in all these procedures. Debugging this really got me frustrated XD, but it was worth my while.
Thank you again!
Iffa_Intel
Greetings,
I'm not quite sure wht the demo is not working for you.
First and foremost, ensure that you had installed the pre-requisite (it should install every necessary things) --in Linux ensure to include sudo
Another workaround is:
Go to directory <openvino version>/ deployment tool/ tools/model_downloader
Then run the command: python downloader.py --print_all
you can see the list of all officially supported models including squeezenet
to download type in command: python downloader.py --name squeezenet1.1
(for example)
and see whether you could successfully implement it.
you can refer here for more detailed explaination:
https://www.youtube.com/watch?v=cbdS3BjjbaQ
Sincerely,
Iffa
Lablace
Thank you, Iffa.
) else (
Thank you again!
Max_L_Intel
Improvements were merged to GitHub master: https://github.com/openvinotoolkit/openvino/commit/298506fb14cc33c581d15bab2e357f374b58cd78
  1. Passing parameters issue seems to be a consequence of cd call without option /d . --"Eventually I have managed to work it out or so"..
  2. Added  /d for cd calls*.*
  3. Improved Visual Studio version detection for a case if it installed to not default location
  4. Last one is the user environment issue:
    1.  The issue came from mixed Release and Debug Library and cldnn_global_custom_kernels.
    2. https://software.intel.com/content/www/us/en/develop/articles/entry-point-__libm_sse2_cbrtf-could-not-be-located-in-libmmddll.html
           Product was moved from Intel Compiler to Visual Studio by default, so we will not face with it in a future releases.
Iffa_Intel
Glad to hear that you able to solve that problem!.
I'll make sure your points are noted.
Thanks & Have a great day ahead.
Sincerely,
Iffa
