I'm trying to install correctly openvino toolkit on raspberry pi4 with unbuntu 18.04 by following this tuto:
When I want to build Python API with the following cmake command:
cmake -DENABLE_PYTHON=ON -DPYTHON_EXECUTABLE=`which python3.6` -DPYTHON_LIBRARY=/usr/lib/x86_64-linux-gnu/libpython3.6m.so -DPYTHON_INCLUDE_DIR=/usr/include/python3.6 ..
It says the following error:
By not providing "FindInferenceEngineDeveloperPackage.cmake" in
CMAKE_MODULE_PATH this project has asked CMake to find a package
configuration file provided by "InferenceEngineDeveloperPackage", but CMake
did not find one.
Could not find a package configuration file provided by
"InferenceEngineDeveloperPackage" with any of the following names:
InferenceEngineDeveloperPackageConfig.cmake
inferenceenginedeveloperpackage-config.cmake
Add the installation prefix of "InferenceEngineDeveloperPackage" to
CMAKE_PREFIX_PATH or set "InferenceEngineDeveloperPackage_DIR" to a
directory containing one of the above files. If
"InferenceEngineDeveloperPackage" provides a separate development package
or SDK, be sure it has been installed.
I have no idea where this package is located.
For opencv I downloaded myself from here:
https://docs.opencv.org/master/d2/de6/tutorial_py_setup_in_ubuntu.html
Did I miss something please?
Hi @Thib,
Looks like you posted this very same question in GitHub repo https://github.com/openvinotoolkit/openvino/issues/1428, I will continue to assist you in there. My response was as follows:
"If I am not mistaken I believe your paths above are slightly inaccurate. Are you using Ubuntu Server 18.04 64-bit? If so for Python, v3.6.9 for example, the cmake command would look similar to:
cmake -DENABLE_PYTHON=ON \
-DPYTHON_EXECUTABLE=/usr/bin/python3.6 \
-DPYTHON_LIBRARY=/usr/lib/aarch64-linux-gnu/libpython3.6m.so \
-DPYTHON_INCLUDE_DIR=/usr/include/python3.6 \
Also make sure to install all additional packages listed in the /inference-engine/ie_bridges/python/requirements.txt file:
pip install -r requirements.txt
Let me know if issue persists or you have any additional questions."
Luis
Hi @Thib,
According to issue in GitHub #1248 this has been resolved as per your comment: "Thanks for help, I solved my problem.
Luis
