R5 vs R3 problems on GPU object_detection_sample_ssd
Stefano_M_
Before R5 I was using R3.343 on Intel® Celeron® N3160 with Windows 10 Enterprise LTSB (version 1607 - Build: 14393.693)
Intel HD Graphics driver version: 20.19.15.4531 - 29/09/2016
object_detection_sample_ssd in R3.343 was working both in CPU and in GPU mode (only in FP32 precision)
this was the output for initialization:
[ INFO ] InferenceEngine:
        API version ............ 1.2
        Build .................. 13911
[ INFO ] Loading plugin:
        Build .................. cldnn/GEN_GPU_clDNN_ci-main_cldnn-main-03988_artifacts.zip
        Description ....... clDNNPlugin
Now, with R5 (same S.O. and GPU drivers) the GPU mode is not working (both in FP32 and in FP16).
The sample gives me this error: [ ERROR ] Device lookup failed - unsupported device id: 0x22B1. Note: HD5xx+ devices are supported
this is the output on the initializazion:
        API version ............ 1.4
        Build .................. 19154
        API version ............ 1.5
Is there something that I can do to run the sample with R5 in GPU mode?
nikos1
Valued Contributor I
Most likely similar issue to https://software.intel.com/en-us/forums/computer-vision/topic/800219
but could be also that was supported before and not supported now due to new clDNN requirements for newer OpenCL extensions.
Can you post clinfo output please?
Stefano_M_
How can I get clinfo output?
nikos1
On Ubuntu just install clinfo and run from command line.
On Windows it is a bit harder but please search for a binary or build from source.
A clinfo.exe binary for example is attached in https://boinc.mundayweb.com/wiki/index.php?title=Determine_OpenCL_capability_of_GPU_and_CPU
