Community
cancel
Showing results for
Search instead for
Did you mean:
ha__minh_quyet
RuntimeError: Nested loops are not supported yet
Dear all,
I am using OpenVINO toolkit release 2020.1 in Ubuntu 16. I got the runtime error as below while try to inference a LSTM-based model in MYRIAD plugin:
  File "inference.py", line 54, in <module>
    sys.exit(main() or 0)
  File "inference.py", line 34, in main
    exec_net, input_blob = load_network(args)
  File "/home/majinbuu/Documents/asr-ncs/asr/utils_inference.py", line 45, in load_network
    exec_net = ie.load_network(network=net, device_name=args.device)
  File "ie_api.pyx", line 134, in openvino.inference_engine.ie_api.IECore.load_network
  File "ie_api.pyx", line 141, in openvino.inference_engine.ie_api.IECore.load_network
RuntimeError: Check (currentLoopAttributes == nullptr) failed: Nested loops are not supported yet
HA Minh Quyet
Hi HA Minh Quyet,
Can you please provide your model so we can take a look at it. Also, what framework was your model trained in? Is it a custom or pre-trained model? Can you provide the commands you used to convert your model and the commands you used to deploy the model in the Inference Engine?
Randall B.
ha__minh_quyet
Dear Randall,
I used Tensorflow to train my model. It is a custom model based on LSTM cell. Is there any private way to upload the model? Because I am not allowed to public the model. The command used to convert my model as follows:
python /opt/intel/openvino/deployment_tools/model_optimizer/mo_tf.py --input_model model/tf_model/asr_horovod_nchw-12.pb --output_dir model/ir_model/ --model_name asr_VPU_ir_r3_12 --data_type FP16 --log_level DEBUG --input_shape [1,1,1000,161] --disable_nhwc_to_nchw
HA Minh Quyet
Sahira_Intel
HA Minh Quyet,
I have sent you a PM, please attach your model there and we can take a look at it.
Sahira
