- Email to a Friend
I'm trying to build this pretrained demo model. The model is restored and works fine in Tensorflow1.7 (python3.5). The graph of this model contains operation TensorArrayV3. I freeze the model for inference (described here) and try to compile the graph using the mvNCCompile utility. The mvNCCompile utility returns this error: "Error [Error 5] Toolkit Error: Stage details are not supported: TensorArrayV3". I use ncsdk-2.05.00.02. How to solve this problem?
- Tags:
- Tensorflow
- Email to a Friend
@dimm84 The NCSDK don't have support for this op yet, but thank you for bringing this to our attention. At the moment, the model you are using won't be able to run on the NCSDK. You can try using OpenVINO with the NCS and see if it works. Link to OpenVINO: https://software.intel.com/en-us/openvino-toolkit
