Tensorflow image resize not supported?
I'm using mvNCCompile v2.00 and want to compile this https://github.com/fizyr/keras-retinanet to use in Movidius.
The problem is, I need the tensorflow.image.resize_images but it doesn't support in mvNCCompile.
Hi @DableUTeeF
There are operations and layers that Keras models use that are not supported by mvnCCompile. You must first convert your Keras model to a Tensorflow model, then compile into an NCS graph, and _then_ deploy on your NCS1. Here is a good guide on how to convert from keras to .pb.
Please let me know if you have any further questions.
Sahira
