6605 Discussions
The HDDL-R8 accelerator card has a very low usage rate when running the official demo.
kman066
Hi:
  I am Kman.When i use the HDDL-R8 accelerator card to run the official demo.The fps are very low,and it showed a very low "util%". This phenomenon is very metaphysical.My hardware configuration is as follows:
CPU: i3  8145UE
Vision Accelerator Card: hddl-R8
OS: Ubuntu18.04
OpenVINO:2020.4
Max_L_Intel
Hi @WU__Tianwen
That might depend on different settings and exact hardware that you test, but generally that should not be the case. We have very limited performance benchmark results, but there you can see that Vision Accelerator Design with VPUs (HDDL) shows higher performance for "Throughput" section for FP16 comparing even to Core i7 for INT8 precision.
Usually we recommend to use Benchmark App within OpenVINO package to measure the performance.
XFR1998
fxxk!!! I have the same problem as u.......I need help
Max_L_Intel
Hi @kman066
It might be sufficient for your application and model to utilize this amount of HDDL card resources to parallelize the execution as much as possible.
Also, it is recommended to have at minimum 32 inference requests in flight to fully saturate the device. See Request-Based API and “GetBlob” Idiom and Benchmark App Sample (-nireq parameter) for more information.
WU__Tianwen
Hello,@Max_L_Intel !
I also do some test on HDDL-R8.https://github.com/TNTWEN/OpenVINO-YOLOV4/issues/5
In YOLO video test,It seems that the speed of HDDL-R8 is slower than intel GPU.Is this normal? I wonder if this is the limit of hddlr8's performance
Thanks a lot!
Max_L_Intel
Hi @WU__Tianwen
Max_L_Intel
This thread will no longer be monitored since we have provided our suggestions. If you need any additional information from Intel, please submit a new question.
