I have been working in a project using Yolo v2 with darkflow in the Movidius.
In: https://github.com/fernandodelacalle/yolo-darkflow-movidius you can find my code, with and example and instructions also with a dokerfile and a demo web app using flask.
Hope some of you find it useful!!
@fdnn Nice! Thanks for posting this. I was able to run it with no issues.
@fdnn @Tome_at_Intel
I have some problems in this example, the operation process is done according to your requirements.
File "/usr/local/bin/mvNCCompile", line 169, in
create_graph(args.network, args.image, args.inputnode, args.outputnode, args.outfile, args.nshaves, args.inputsize, args.weights, args.explicit_concat, args.ma2480, args.scheduler, args.new_parser, args)
File "/usr/local/bin/mvNCCompile", line 148, in create_graph
load_ret = load_network(args, parser, myriad_config)
File "/usr/local/bin/ncsdk/Controllers/Scheduler.py", line 100, in load_network
parse_ret = parse_tensor(arguments, myriad_conf)
File "/usr/local/bin/ncsdk/Controllers/TensorFlowParser.py", line 385, in parse_tensor
int(input_shape[1]),
TypeError: int returned non-int (type NoneType)
Can you give me some help, thank you
@fdnnI solved the above problem, but I have an error when I run yolov2 in moveidius.When I run python3 test_movidius.py -i video.avi, the following error occurs.
song@sgj:~/workspace/yolo-darkflow-movidius$ python3 test_movidius.py -i video.avi
D: [ 0] ncDeviceCreate:307 ncDeviceCreate index 0
D: [ 0] ncDeviceCreate:307 ncDeviceCreate index 1
D: [ 0] ncDeviceOpen:501 File path /usr/local/lib/mvnc/MvNCAPI-ma2450.mvcmd
I: [ 0] ncDeviceOpen:507 ncDeviceOpen() XLinkBootRemote returned success 0
I: [ 0] ncDeviceOpen:536 XLinkConnect done - link Id 0
D: [ 0] ncDeviceOpen:550 done
I: [ 0] ncDeviceOpen:552 Booted 1.4-ma2450 -> VSC
I: [ 0] getDevAttributes:373 Device attributes
I: [ 0] getDevAttributes:376 Device FW version: 2.4.2450.f0
I: [ 0] getDevAttributes:378 mvTensorVersion 2.4
I: [ 0] getDevAttributes:379 Maximum graphs: 10
I: [ 0] getDevAttributes:380 Maximum fifos: 20
I: [ 0] getDevAttributes:382 Maximum graph option class: 1
I: [ 0] getDevAttributes:384 Maximum device option class: 1
I: [ 0] getDevAttributes:385 Device memory capacity: 522073264
I: [ 0] ncGraphAllocate:923 Starting Graph allocation sequence
I: [ 0] ncGraphAllocate:988 Sent graph
D: [ 0] ncGraphAllocate:1013 Graph Status 0 rc 0
D: [ 0] ncGraphAllocate:1059 Input tensor w 416 h 416 c 3 n 1 totalSize 1038336 wstide 6 hstride 2496 cstride 2 layout 0
D: [ 0] ncGraphAllocate:1072 output tensor w 13 h 13 c 50 n 1 totalSize 16900 wstide 100 hstride 1300 cstride 2 layout 0
I: [ 0] ncGraphAllocate:1126 Graph allocation completed successfully
I: [ 0] ncFifoCreate:2126 Init fifo
I: [ 0] ncFifoAllocate:2321 Creating fifo
D: [ 0] ncFifoWriteElem:2592 No layout conversion is needed 0
D: [ 0] convertDataTypeAndLayout:170 src data type 1 dst data type 0
D: [ 0] convertDataTypeAndLayout:172 SRC: w 416 h 416 c 3 w_s 12 h_s 4992 c_s 4
D: [ 0] convertDataTypeAndLayout:174 DST: w 416 h 416 c 3 w_s 6 h_s 2496 c_s 2
D: [ 0] ncFifoWriteElem:2617 write count 0 num_elements 2 userparam 0x7fd040469ef0
I: [ 0] ncGraphQueueInference:3048 trigger start
I: [ 0] ncGraphQueueInference:3145 trigger end
D: [ 0] ncFifoReadElem:2686 No layout conversion is needed 0
D: [ 0] convertDataTypeAndLayout:170 src data type 0 dst data type 1
D: [ 0] convertDataTypeAndLayout:172 SRC: w 13 h 13 c 50 w_s 100 h_s 1300 c_s 2
D: [ 0] convertDataTypeAndLayout:174 DST: w 13 h 13 c 50 w_s 200 h_s 2600 c_s 4
D: [ 0] ncFifoReadElem:2714 num_elements 2 userparam 0x7fd04047a1a8 output length 33800
/usr/local/lib/python3.5/dist-packages/mvnc/mvncapi.py:418: DeprecationWarning: The binary mode of fromstring is deprecated, as it behaves surprisingly on unicode inputs. Use frombuffer instead
tensor = numpy.fromstring(tensor.raw, dtype=numpy.float32)
FPS: 3.92
File "test_movidius.py", line 110, in
main()
File "test_movidius.py", line 107, in main
args.threshold)
File "test_movidius.py", line 65, in inference_video
y_out = np.reshape(output, (13, 13,125))
File "/home/songgongjun/.local/lib/python3.5/site-packages/numpy/core/fromnumeric.py", line 279, in reshape
return _wrapfunc(a, 'reshape', newshape, order=order)
File "/home/songgongjun/.local/lib/python3.5/site-packages/numpy/core/fromnumeric.py", line 51, in _wrapfunc
return getattr(obj, method)(*args, **kwds)
ValueError: cannot reshape array of size 8450 into shape (13,13,125)
I don't know where the problem is.
Hi @songgongjun could you tell me:
1- the size of the variable frame before and after this assignment: frame = yolo_utils.pre_proc_img(frame, meta)
2- the contents of the meta dict.
@fdnn Thank you, I have solved my problem.
@fdnn. I have a model saved using the save_pb command in darkflow and was planning to run it on NCS. Is it must, to freeze the tf graph before saving it as a pb file, to have it run on NCS?
I am trying to deploy customized YOLO network. It is a tensorflow implementation of yolo v2. I am getting same error as yours, Can you post your solution that how did you solved this?
res.shape: (1, 13, 13, 3, 8)
File "/usr/local/bin/mvNCCompile", line 206, in <module>
create_graph(args.network, args.image, args.inputnode, args.outputnode, args.outfile, args.nshaves, args.inputsize, args.weights, args.explicit_concat, args.ma2480, args.scheduler, args.new_parser, args.cpp, args)
File "/usr/local/bin/mvNCCompile", line 185, in create_graph
File "/usr/local/bin/ncsdk/Controllers/Scheduler.py", line 146, in load_network
File "/usr/local/bin/ncsdk/Controllers/TensorFlowParser.py", line 1751, in parse_tensor
res = res.reshape(1, 1, res.shape[0])
ValueError: cannot reshape array of size 4056 into shape (1,1,1)
Can you share the guidelines for compiling yolo network with Movidius.
For more complete information about compiler optimizations, see our Optimization Notice.
