Community support and discussions about the Intel® Distribution of OpenVINO™ toolkit, OpenCV, and all things computer vision-related on Intel® platforms.
6102 Discussions
Toolkit Error: Stage Details Not Supported
Hi , I'm hyunwoo lee.
I got some error message after I conveted model to graph using movidius sdk .
[Error 5] Toolkit Error: Stage Details Not Supported: Top Not Found module_apply_default/hub_input/Sub
I trained model using tensorflow-hub.
I read simmilar issue (https://ncsforum.movidius.com/discussion/comment/2524/#Comment_2524) and understood it's a problem about bottleneck
but I couldn't find a solution.
Can I have a simple solution to fix this problem?
@hyunwoolee Can you provide a link to your model for testing? The NCSDK is designed for deployment and as such all layers (dropout layer, etc) related to training must be removed. It seems like your model is still expecting some data from the node module_apply_default/hub_input/Sub.
Unfortunately , I cannot upload the model file because of our company's security system.
but I retrained model using this code. (https://github.com/tensorflow/hub/tree/master/examples/image_retraining)
So you can check it right after little learning using dummy data.
@Tome_at_Intel Hi. any update on this thread?
@hyunwoolee Correct me if I am mistaken, but your model seems to be expecting another data input. It seems this data doesn't exist and that's why the NCSDK is throwing the error. The issue could be because the NCS doesn't support multiple inputs. If possible, everything should be "baked" into your model, so that it isn't expecting any other external input besides the input image.
