USB Case size issues
From the pic, you can see that the Movidius USB case is too large and prevents us of the next slot over on a Pi3.
I understand that a USB hub could alleviate this, but that is impractical for IoT and wearables which emphasize small size.
Q1: Although it may void the warranty, is there an easy\best\safest way to remove the case?
Q2: Is a new USB case design possible, which is friendlier to this common USB config on IoT devices?
I would love to buy a design friendlier to the Pi Zero (micro-USB?), when supported.
@spinoza1791 I understand the problem that the size of the NCS case can cause. We are considering a change for a future revision of the device. Thanks.
